I am running Ubuntu GNOME 15.10 with GNOME 3.18 and would like to know if there is some way to get CTRL + ALT + T to open a new Terminal window even if one is already open (that is rather than just bring the currently open one to the front)?
            Asked
            Active
            Viewed 7.8k times
16
            The funny thing is that on Unity, CTRL + ALT + T does open a new window, apparantly not on Gnome...
To make the setup:
- First disable the existing command/key combination with the command: - gsettings set org.gnome.settings-daemon.plugins.media-keys terminal ""- Which will make CTRL + ALT + T "available" again for another command.
- Now open keyboard settings: System Settings > "Keyboard" > "Shortcuts" > "Custom Shortcuts". Click the "+" and add the command: - gnome-terminal --window-with-profile=<profilename>- to CTRL + ALT + T, where - <profilename>is the name of your profile, most likely- Default
From man gnome-terminal:
   --window-with-profile=PROFILENAME
             Open  a new window containing a tab with the given profile.
             More than one of these options can be provided.
        Jacob Vlijm
- 85,475
14
        It's pretty easy to make Ctrl+Alt+T alive in gnome:
- Search for Keyboard shortcuts in Gnome home menu
- Add a custom shortcut in Keyboard
- Add (+) - Name: gnome-terminal
- Command: gnome-terminal
- Ctrl+Alt+T
        David Foerster
- 36,890
- 56
- 97
- 151
        Kurian Benoy
- 711
