Recently I installed Ubuntu into VirtualBox. The problem was that the resolution was really small and it stayed small even when I enlarge it by going to view → switch to full screen. I searched and found this solution:
sudo apt-get install virtualbox-guest-dkms
which fails with this error message:
File "/usr/share/apport/package-hooks/dkms_packages.py", line 98, in <module>
with apport.fileutils.make_report_file(report) as f: AttributeError: 'module' object has no attribute 'make_report_file'
Error! Bad return status for module build on kernel: 3.19.0-25-generic (x86_64)
Consult /var/lib/dkms/virtualbox-guest/4.3.10/build/make.log for more information
Content of the log file:
DKMS make.log for virtualbox-guest-4.3.10 for kernel 3.19.0-25-generic (x86_64)
Mi 18. Nov 11:15:34 CET 2015
make: Entering directory `/usr/src/linux-headers-3.19.0-25-generic'
  LD      /var/lib/dkms/virtualbox-guest/4.3.10/build/built-in.o
  LD      /var/lib/dkms/virtualbox-guest/4.3.10/build/vboxguest/built-in.o
  CC [M]  /var/lib/dkms/virtualbox-guest/4.3.10/build/vboxguest/VBoxGuest-linux.o
  CC [M]  /var/lib/dkms/virtualbox-guest/4.3.10/build/vboxguest/VBoxGuest.o
/var/lib/dkms/virtualbox-guest/4.3.10/build/vboxguest/VBoxGuest.c: In function ‘VBoxGuestCommonGetHandledEventsLocked’:
/var/lib/dkms/virtualbox-guest/4.3.10/build/vboxguest/VBoxGuest.c:82:5: warning: ISO C90 forbids mixed declarations and code [-Wdeclaration-after-statement]
     uint32_t u32AllowedGuestCaps = pSession->u32AquiredGuestCaps | (VMMDEV_EVENT_VALID_EVENT_MASK & ~pDevExt->u32AcquireModeGuestCaps);
/var/lib/dkms/virtualbox-guest/4.3.10/build/vboxguest/VBoxGuest.c:2660:5: warning: ISO C90 forbids mixed declarations and code [-Wdeclaration-after-statement]
     uint32_t fGenFakeEvents = 0;
/var/lib/dkms/virtualbox-guest/4.3.10/build/vboxguest/VBoxGuest.c: In function ‘VBoxGuestCommonIOCtl’:
/var/lib/dkms/virtualbox-guest/4.3.10/build/vboxguest/VBoxGuest.c:2807:9: warning: ISO C90 forbids mixed declarations and code [-Wdeclaration-after-statement]
         VBoxGuestHGCMCallInfoTimed *pInfo = (VBoxGuestHGCMCallInfoTimed *)pvData;
  CC [M]  /var/lib/dkms/virtualbox-guest/4.3.10/build/vboxguest/VBoxGuest2.o
  CC [M]  /var/lib/dkms/virtualbox-guest/4.3.10/build/vboxguest/GenericRequest.o
  CC [M]  /var/lib/dkms/virtualbox-guest/4.3.10/build/vboxguest/HGCMInternal.o
  CC [M]  /var/lib/dkms/virtualbox-guest/4.3.10/build/vboxguest/Init.o
/Init.o
  CC [M]  /var/lib/dkms/virtualbox-guest/4.3.10/build/vboxguest/PhysHeap.o
  CC [M]  /var/lib/dkms/virtualbox-guest/4.3.10/build/vboxguest/SysHlp.o
  CC [M]  /var/lib/dkms/virtualbox-guest/4.3.10/build/vboxguest/VMMDev.o
  CC [M]  /var/lib/dkms/virtualbox-guest/4.3.10/build/vboxguest/r0drv/alloc-r0drv.o
  CC [M]  /var/lib/dkms/virtualbox-guest/4.3.10/build/vboxguest/r0drv/initterm-r0drv.o
  CC [M]  /var/lib/dkms/virtualbox-guest/4.3.10/build/vboxguest/r0drv/memobj-r0drv.o
  CC [M]  /var/lib/dkms/virtualbox-guest/4.3.10/build/vboxguest/r0drv/mpnotification-r0drv.o
  CC [M]  /var/lib/dkms/virtualbox-guest/4.3.10/build/vboxguest/r0drv/powernotification-r0drv.o
  CC [M]  /var/lib/dkms/virtualbox-guest/4.3.10/build/vboxguest/r0drv/linux/alloc-r0drv-linux.o
/var/lib/dkms/virtualbox-guest/4.3.10/build/vboxguest/r0drv/linux/alloc-r0drv-linux.c: In function ‘rtR0MemAllocExecVmArea’:
/var/lib/dkms/virtualbox-guest/4.3.10/build/vboxguest/r0drv/linux/alloc-r0drv-linux.c:194:9: warning: passing argument 3 of ‘map_vm_area’ from incompatible pointer type [enabled by default] if (!map_vm_area(pVmArea, PAGE_KERNEL_EXEC, &papPagesIterator)) ^ In file included from ./arch/x86/include/asm/io.h:200:0, from ./arch/x86/include/asm/realmode.h:5, from ./arch/x86/include/asm/acpi.h:33, from ./arch/x86/include/asm/fixmap.h:19, from ./arch/x86/include/asm/apic.h:12, from ./arch/x86/include/asm/smp.h:12, from ./arch/x86/include/asm/mmzone_64.h:10, from ./arch/x86/include/asm/mmzone.h:4, from include/linux/mmzone.h:912, from include/linux/gfp.h:5, from include/linux/slab.h:14, from /var/lib/dkms/virtualbox-guest/4.3.10/build/vboxguest/r0drv/linux/the-linux-kernel.h:72, from /var/lib/dkms/virtualbox-guest/4.3.10/build/vboxguest/r0drv/linux/alloc-r0drv-linux.c:31: include/linux/vmalloc.h:115:12: note: expected ‘struct page ’ but argument is of type ‘struct page ’ extern int map_vm_area(struct vm_struct area, pgprot_t prot, ^ CC [M] /var/lib/dkms/virtualbox-guest/4.3.10/build/vboxguest/r0drv/linux/assert-r0drv-linux.o CC [M] /var/lib/dkms/virtualbox-guest/4.3.10/build/vboxguest/r0drv/linux/initterm-r0drv-linux.o CC [M] /var/lib/dkms/virtualbox-guest/4.3.10/build/vboxguest/r0drv/linux/memobj-r0drv-linux.o CC [M] /var/lib/dkms/virtualbox-guest/4.3.10/build/vboxguest/r0drv/linux/memuserkernel-r0drv-linux.o CC [M] /var/lib/dkms/virtualbox-guest/4.3.10/build/vboxguest/r0drv/linux/mp-r0drv-linux.o CC [M] /var/lib/dkms/virtualbox-guest/4.3.10/build/vboxguest/r0drv/linux/mpnotification-r0drv-linux.o CC [M] /var/lib/dkms/virtualbox-guest/4.3.10/build/vboxguest/r0drv/linux/process-r0drv-linux.o CC [M] /var/lib/dkms/virtualbox-guest/4.3.10/build/vboxguest/r0drv/linux/semevent-r0drv-linux.o CC [M] /var/lib/dkms/virtualbox-guest/4.3.10/build/vboxguest/r0drv/linux/semeventmulti-r0drv-linux.o CC [M] /var/lib/dkms/virtualbox-guest/4.3.10/build/vboxguest/r0drv/linux/semfastmutex-r0drv-linux.o CC [M] /var/lib/dkms/virtualbox-guest/4.3.10/build/vboxguest/r0drv/linux/semmutex-r0drv-linux.o CC [M] /var/lib/dkms/virtualbox-guest/4.3.10/build/vboxguest/r0drv/linux/spinlock-r0drv-linux.o CC [M] /var/lib/dkms/virtualbox-guest/4.3.10/build/vboxguest/r0drv/linux/thread-r0drv-linux.o CC [M] /var/lib/dkms/virtualbox-guest/4.3.10/build/vboxguest/r0drv/linux/thread2-r0drv-linux.o CC [M] /var/lib/dkms/virtualbox-guest/4.3.10/build/vboxguest/r0drv/linux/time-r0drv-linux.o CC [M] /var/lib/dkms/virtualbox-guest/4.3.10/build/vboxguest/r0drv/linux/RTLogWriteDebugger-r0drv-linux.o CC [M] /var/lib/dkms/virtualbox-guest/4.3.10/build/vboxguest/r0drv/generic/semspinmutex-r0drv-generic.o /common/alloc/alloc.o CC [M] /var/lib/dkms/virtualbox-guest/4.3.10/build/vboxguest/common/err/RTErrConvertFromErrno.o CC [M] /var/lib/dkms/virtualbox-guest/4.3.10/build/vboxguest/common/err/RTErrConvertToErrno.o CC [M] /var/lib/dkms/virtualbox-guest/4.3.10/build/vboxguest/common/log/log.o CC [M] /var/lib/dkms/virtualbox-guest/4.3.10/build/vboxguest/common/log/logellipsis.o CC [M] /var/lib/dkms/virtualbox-guest/4.3.10/build/vboxguest/common/log/logrel.o CC [M] /var/lib/dkms/virtualbox-guest/4.3.10/build/vboxguest/common/log/logrelellipsis.o CC [M] /var/lib/dkms/virtualbox-guest/4.3.10/build/vboxguest/common/log/logcom.o CC [M] /var/lib/dkms/virtualbox-guest/4.3.10/build/vboxguest/common/log/logformat.o CC [M] /var/lib/dkms/virtualbox-guest/4.3.10/build/vboxguest/common/misc/RTAssertMsg1Weak.o CC [M] /var/lib/dkms/virtualbox-guest/4.3.10/build/vboxguest/common/misc/RTAssertMsg1Weak.o CC [M] /var/lib/dkms/virtualbox-guest/4.3.10/build/vboxguest/common/misc/RTAssertMsg2.o CC [M] /var/lib/dkms/virtualbox-guest/4.3.10/build/vboxguest/common/misc/RTAssertMsg2Add.o CC [M] /var/lib/dkms/virtualbox-guest/4.3.10/build/vboxguest/common/misc/RTAssertMsg2AddWeak.o CC [M] /var/lib/dkms/virtualbox-guest/4.3.10/build/vboxguest/common/misc/RTAssertMsg2AddWeakV.o CC [M] /var/lib/dkms/virtualbox-guest/4.3.10/build/vboxguest/common/misc/RTAssertMsg2Weak.o CC [M] /var/lib/dkms/virtualbox-guest/4.3.10/build/vboxguest/common/misc/RTAssertMsg2WeakV.o CC [M] /var/lib/dkms/virtualbox-guest/4.3.10/build/vboxguest/common/misc/assert.o CC [M] /var/lib/dkms/virtualbox-guest/4.3.10/build/vboxguest/common/misc/thread.o CC [M] /var/lib/dkms/virtualbox-guest/4.3.10/build/vboxguest/common/string/RTStrCopy.o CC [M] /var/lib/dkms/virtualbox-guest/4.3.10/build/vboxguest/common/string/RTStrCopyP.o CC [M] /var/lib/dkms/virtualbox-guest/4.3.10/build/vboxguest/common/string/RTStrCopyP.o CC [M] /var/lib/dkms/virtualbox-guest/4.3.10/build/vboxguest/common/string/strformat.o CC [M] /var/lib/dkms/virtualbox-guest/4.3.10/build/vboxguest/common/string/strformatrt.o CC [M] /var/lib/dkms/virtualbox-guest/4.3.10/build/vboxguest/common/string/strformattype.o CC [M] /var/lib/dkms/virtualbox-guest/4.3.10/build/vboxguest/common/string/strprintf.o CC [M] /var/lib/dkms/virtualbox-guest/4.3.10/build/vboxguest/common/string/strtonum.o CC [M] /var/lib/dkms/virtualbox-guest/4.3.10/build/vboxguest/common/table/avlpv.o CC [M] /var/lib/dkms/virtualbox-guest/4.3.10/build/vboxguest/common/time/time.o /var/lib/dkms/virtualbox-guest/4.3.10/build/vboxguest/common/time/time.c: In function ‘VBoxGuest_RTTimeFromString’: ... /var/lib/dkms/virtualbox-guest/4.3.10/build/vboxsf/dirops.c:129:29: error: ‘struct file’ has no member named ‘f_dentry’ sf_g = GET_GLOB_INFO(dir->f_dentry->d_inode->i_sb); ^ /var/lib/dkms/virtualbox-guest/4.3.10/build/vboxsf/vfsmod.h:144:60: note: in definition of macro ‘GET_GLOB_INFO’
define GET_GLOB_INFO(sb) ((struct sf_glob_info *) (sb)->s_fs_info)
/var/lib/dkms/virtualbox-guest/4.3.10/build/vboxsf/dirops.c:135:16: error: ‘struct file’ has no member named ‘f_dentry’ inode = dir->f_dentry->d_inode; ^ make[2]: *** [/var/lib/dkms/virtualbox-guest/4.3.10/build/vboxsf/dirops.o] Error 1 make[1]: *** [/var/lib/dkms/virtualbox-guest/4.3.10/build/vboxsf] Error 2 make: *** [module/var/lib/dkms/virtualbox-guest/4.3.10/build] Error 2 make: Leaving directory `/usr/src/linux-headers-3.19.0-25-generic' ~
How can I fix this problem?
double-beep
  • 195
  • 13
mark
  • 131
There is another way to do this, which I prefer.
  1. Open Terminal
  2. sudo apt-get update && upgrade -y
  3. Once complete run: sudo apt-get install build-essential
  4. On the running VirtualBox window along the top select Devices > Insert Guest addons cd image.
  5. In your terminal navigate to: cd /media/USERNAME/ and run ls to then see what the virtual disc is called in my case it is VBOXADDITIONS_5.0.10_104061 and cd to it.
  6. Now in the folder run sudo sh ./VBoxLinuxAdditions.run
  7. Wait for it to finish
  8. Reboot and Enjoy.
Let me know how you get on.
lordqwerty
  • 507
  • 19
Finally, I managed to solve the problem. In my case, the problem was that I was running older VirtualBox and after updating it, the command virtualbox-guest-dkms worked and I could switch to full screen mode.
mark
  • 131
