Just bought a new nvidia GPU (GTX 980 Ti) and installed it on motherboard. When boot up, a low-resolution login screen appears. Typed in password, see a flash, then it takes me back to the same login screen. No matter how many times I try, couldn't login.
Some background : I have an old GTX 660 Ti on ubuntu 14.04 with nvidia driver version 340.29, which is working just fine. When I install the new card, I DID NOT re-install the driver because I was under the impression that this driver works for newer cards. Another reason is the last time I install nvidia driver, everything broke and it took me weeks to fix all the problems. I'm trying to avoid the nightmare again.
horaceT
  • 274
Use Ubuntu live CD and go for 'Try Ubuntu'.
Have to remount the system partition (where Ubuntu is installed).
sudo mount /dev/sda1     /mnt
sudo mount --bind /dev  /mnt/dev
sudo mount --bind /proc /mnt/proc
sudo mount --bind /sys  /mnt/sys
sudo chroot /mnt
# Remove existing drivers
sudo apt-get remove nvidia*
sudo apt-get purge nvidia*
# Housekeeping
sudo apt-get clean
sudo apt-get autoclean
# Handle any errors to due incomplete apt-get operations
sudo dpkg --configure -a
sudo apt-get update
sudo apt-get upgrade
# Remove xorg/X11/XFree86 references to graphics drivers
sudo rm /etc/X11/xorg.conf
sudo apt-get install ubuntu-desktop
Now, install the nvidia drivers we want:
sudo apt-get install nvidia-current
sudo apt-get install nvidia-common
sudo apt-get install nvidia-304
Now reboot the system.
Sources:
ATR
  • 403
First of all, like to thank ATR for proposing the solution, but for some reason it didn't quite work and I'm still scratching my head as to why. However, just a slight twist is all it takes to make it work.
Instead of booting from an Ubuntu Live CD, I boot into the target partition. When the low-resolution login screen appears, I hit Ctrl-Alt-F1, which takes me to command line. Login as either admin or limited user, then recite the same incantation,
sudo apt-get clean
sudo apt-get update
sudo apt-get install ubuntu-desktop # this may not be needed
sudo apt-get install nvidia-352
reboot
Notice that since I'm booting into the hard drive, I don't need to mount those folders as in ATR's solution.
To check,
modinfo nvidia
horaceT
  • 274
