I have this .desktop file set to update my software:
[Desktop Entry]
Version=1.0
Type=Application
Name=Update Software
Comment=Application
Exec=/home/david/Update_Script.sh
Icon=/home/david/Downloads/upgrade.jpg
Categories=Application;
Terminal=true
However, it launches Terminal, where I would prefer xterm. So do not mark this as a duplicate of this. I want the file to open xterm and then close xterm when the script is done. Here is what the script looks like currently:
sudo apt-get upgrade
sudo apt-get update
sudo apt-get install -f
sudo apt-get clean
Do I need to add something to the .desktop file or to the script to make it open xterm (and close it when done)?
David
  • 3,487
.desktop and the Ctrl-Alt-T shortcut all launch x-terminal-emulator , which is a symlink to /etc/alternatives/x-terminal-emulator , which in turn is a symlink to /usr/bin/gnome-terminal.wrapper. In short, gnome-terminal aka Terminal is the default terminal emulator on Ubuntu.
If you want to use xterm for just one .desktop file , follow muru's suggestion in the comments and use use
Exec=xterm -e /path/to/script.sh
If you want to globally change the terminal that the system launches by default, run
sudo update-alternatives --config x-terminal-emulator
