Hoping someone can help me out here, im quite new so please excuse any false assumptions.
I recently had a relatives mac boot drive fail(seems mechanically fine, but wont appear in OSX or windows). I decided to try plugging it into one of my macs thats dual booted with ubuntu.
The drive does not appear as a drive normally would, however I can see the computer recognize it when plugged in(so im assuming ill have to force mount it?).
The drive appears in lsusb and dmesg(see below for output), however it doesn't show up in fdisk, dev/ or lsscsi so i dont have a location to force mount from(if that makes sense).
Here is the dmesg output:
phillip@phillip-MacBook:~$ dmesg | tail
[ 831.605083] scsi host4: usb-storage 1-2:1.0
[ 831.605533] usbcore: registered new interface driver usb-storage
[ 831.615541] usbcore: registered new interface driver uas
[ 862.869622] usb 1-2: USB disconnect, device number 4
[ 998.212232] usb 1-2: new high-speed USB device number 5 using ehci-pci
[ 998.348140] usb 1-2: New USB device found, idVendor=1f75, idProduct=0621
[ 998.348152] usb 1-2: New USB device strings: Mfr=4, Product=5, SerialNumber=6
[ 998.348159] usb 1-2: SerialNumber: 1
[ 998.566959] usb-storage 1-2:1.0: USB Mass Storage device detected
[ 998.567521] scsi host5: usb-storage 1-2:1.0
Judging by the output of successful mounts ive seen, should it not be handing that off to another process?
Edit: Im just realizing now that it says using "ehci-pci"........im pretty sure one of the earlier times I was toying with this is it was "uhci".....does that make sense?
Here is the lsusb output:(drive is device 6 in list)
phillip@phillip-MacBook:~$ lsusb
Bus 002 Device 002: ID 05ac:8300 Apple, Inc. Built-in iSight (no firmware loaded)
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 007 Device 003: ID 05ac:0229 Apple, Inc. Internal Keyboard/Trackpad (MacBook Pro) (ANSI)
Bus 007 Device 002: ID 05ac:8242 Apple, Inc. Built-in IR Receiver
Bus 007 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 001 Device 006: ID 1f75:0621 Innostor Technology Corporation
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 003 Device 003: ID 05ac:8205 Apple, Inc. Bluetooth HCI
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Here is sudo blkid:
/dev/sda1: LABEL="EFI" UUID="70D6-1701" TYPE="vfat"
/dev/sda2: UUID="13bc40a0-e29b-33fd-adb4-c04e173b2ff2" LABEL="Macintosh HD" TYPE="hfsplus"
/dev/sda4: UUID="38a678ae-0c9b-4c1c-a333-f5c9551eb13f" TYPE="ext4"
/dev/sda5: UUID="6b0d0a7f-776e-4534-b618-a21b0aa2ce86" TYPE="swap"
Output of lsusb -D /dev/bus/usb/002/005
phillip@phillip-MacBook:~$ lsusb -D /dev/bus/usb/002/005
Device: ID 1f75:0621 Innostor Technology Corporation
Couldn't open device, some information will be missing
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.10
bDeviceClass 0 (Defined at Interface level)
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 64
idVendor 0x1f75 Innostor Technology Corporation
idProduct 0x0621
bcdDevice 0.36
iManufacturer 4
iProduct 5
iSerial 6
bNumConfigurations 1
Configuration Descriptor:
bLength 9
bDescriptorType 2
wTotalLength 32
bNumInterfaces 1
bConfigurationValue 1
iConfiguration 0
bmAttributes 0x80
(Bus Powered)
MaxPower 500mA
Interface Descriptor:
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 2
bInterfaceClass 8 Mass Storage
bInterfaceSubClass 6 SCSI
bInterfaceProtocol 80 Bulk-Only
iInterface 0
Endpoint Descriptor:
bLength 7
bDescriptorType 5
bEndpointAddress 0x81 EP 1 IN
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
wMaxPacketSize 0x0200 1x 512 bytes
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x02 EP 2 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
Anybody have any suggestions on where to go next?
Thanks in advance!
