This bluetooth mouse doesn't work out of box, but I found a solution how to make it work. After this a cursor is moved, even though mouse's type is still "any device". So, it works, but I found a strange side effect: when the mouse is on, the my wifi connection is very slow. I made plot of ping to a my wifi-router to demonstrate a affects with on/off the mouse. When the mouse is off, ping ~1 ms, but when mouse is on, ping ~20k(!) ms. My system is ASUS UX31a laptop with Ubuntu 15.10 and I haven't a Windows or other laptops with bluetooth 4.0 to test if the effect exists on other systems. So I can't say it is a bug of Ubuntu or hardware (ux31a have a WLAN and BT4.0 on the one plate, may be it is important).
sdorof
  • 121
Create a following file with the settings to force using wifi g (11n_disable) and disable coexisting (bt_coex_active):
/etc/modprobe.d/iwlwifi-opt.conf (file to be created)
options iwlwifi 11n_disable=1
options iwlwifi bt_coex_active=0
Seems, necessity to disable coexisting is to says about a bug, see here.
sdorof
  • 121
