I've been trying to find a way on how to remove notes on Kubuntu, unfortunately I couldn't. When I right-click on the icon there's no option to remove the note.
I finally found the answer to this. Click and hold on the body of the note, and a little vertical bar will appear to the right of the note. The bar has a red x at the bottom. Release your mouse, click the x, and good riddance to a really really really annoying app.
- 811
If you talk about the same notes as I have on Ubuntu (Simple notebook for GNOME 3.14.2), there is menu button in the top right corner, where you can find option "Move to trash".
- 6,793
If you right-click on your bar, then click on Options and then on Parameters, you'll see another larger bar appear with options to modify the bar. Don't do anything. Just run your mouse over the application you want to close and you'll see a window with a red x in it. Click this and it will close the app.
