My previous computer ran a 32-bit XUbuntu version 14.04 and 32-bit Mozilla Seamonkey as my default web browser. Now my new computer runs a 64-bit Xubuntu version 14.04, but there's no official 64-bit Mozilla Seamonkey build available. I installed the official 32-bit Mozilla Seamonkey on my 64-bit system, but the browser isn't working. When I use the command below in order to try to run its binary executable:
/opt/mozilla/seamonkey/seamonkey
...the program gives me the following reply, before exiting:
libdbus-glib-1.so.2: cannot open shared object file: No such file or directory
Couldn't load XPCOM.
I noticed that my system does have this file here:
/usr/lib/x86_64-linux-gnu/libdbus-glib-1.so.2
...but it's the 64-bit version (most possible reason why the 32-bit Seamonkey is rejecting this library file).
Is there any way to work this around and thus make the 32-bit Seamonkey work in my 64-bit system?
Yuri Sucupira
  • 1,024
  • 15
  • 28
I decided to troubleshoot the problem myself and finally found a workaround.
The first thing you have to do is to activate support for the installation of 32-bit applications in your 64-bit system. You do this by running this shell command:
sudo dpkg --add-architecture i386
After that, all you have to do is to update the APT database:
sudo apt-get update
...and then run the command below in order to install the 32-bit libraries required by Mozilla SeaMonkey:
sudo apt-get install libdbus-glib-1.2:i386 libxt6:i386 libxcomposite1:i386 libstdc++6:i386 libgtk2.0.0:i386 libasound2:i386 -y --reinstall
APT will then solve some dependencies and install them along with the libraries installed by the command above.
I did it in 64-bit XUbuntu versions 14.04 and 16.04 and it worked like a charm: now I can run the official 32-bit build of Mozilla SeaMonkey on my 64-bit system.
Yuri Sucupira
  • 1,024
  • 15
  • 28
For anybody interested, I have a repo with installation scripts for (64-bit) Seamonkey and Firefox here:
https://github.com/sid-the-sloth/install-scripts
Please check it out and enjoy!
A 64-bit version can be downloaded on the main Seamonkey download page under 'Contributed builds'.
