I have installed Ubuntu on Raspberry Pi. When I insert the SD card into the Raspberry Pi, it is taking me to a command window. How do I switch to desktop view or GUI?
I am not able to connect to the Internet to install all libraries.
pradeep
  • 31
You might need to run the following command to install a desktop environment:
tasksel
or
sudo tasksel
However, you will need to connect to the internet.
To connect to the internet, run the following commands.
First, edit the following file using the following command:
sudo nano /etc/wpa_supplicant.conf
Make sure the contents look like this and of course you will need to replace ssid_name with the name of the network and password with the actual password!:
network={
            ssid="ssid_name"
             psk="password"
Press CTRL + o and then press ENTER to save the file. Press CTRL + x to exit nano.
Then, run the following command:
sudo wpa_supplicant -B -iwlan0 -c/etc/wpa_supplicant.conf -Dwext && sudo dhclient wlan0
Finally, check your network connection by running the following command:
iwconfig
Your ESSID should be listed.
Alternatively, you may be able to connect like this instead:
nmcli d wifi connect <WiFiSSID> password <WiFiPassword> iface wlan0
Again, replace <WifiSSID> with the actual name of the network and replace <WiFiPassword> with the actual password.
Additional info 1
Additional info 2
NOTE: because of a bug in tasksel, DO NOT use tasksel to uninstall packages. ONLY use tasksel to install.
mchid
  • 44,904
  • 102
  • 162
