It's the same question like here: Installed 14.04 on a non-PAE (Pentium-M), but now I can't update ("This kernel does not support a non-PAE CPU.")
I get a similar error message:
dpkg: error processing archive /var/cache/apt/archives/linux-image-3.19.0-33-generic_3.19.0-33.38~14.04.1_i386.deb (--unpack):
subprocess new pre-installation script returned error exit status 1
Examining /etc/kernel/postrm.d .
run-parts: executing /etc/kernel/postrm.d/initramfs-tools 3.19.0-33-generic /boot/vmlinuz-3.19.0-33-generic
run-parts: executing /etc/kernel/postrm.d/zz-update-grub 3.19.0-33-generic /boot/vmlinuz-3.19.0-33-generic
Preparing to unpack .../linux-image-3.19.0-30-generic_3.19.0-30.34~14.04.1_i386.deb ...
locale: Cannot set LC_ALL to default locale: No such file or directory
dpkg: error processing archive /var/cache/apt/archives/linux-image-3.19.0-30-generic_3.19.0-30.34~14.04.1_i386.deb (--unpack):
run-parts: executing /etc/kernel/postrm.d/initramfs-tools 3.19.0-30-generic /boot/vmlinuz-3.19.0-30-generic
run-parts: executing /etc/kernel/postrm.d/zz-update-grub 3.19.0-30-generic /boot/vmlinuz-3.19.0-30-generic
But the solution does not help. I have already the forcepae entry in the grub:
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash forcepae"
What else can I do. I'd like to install a DHCP Server. But like this it is not possible.
Check the partitions on your system by performing a sudo df -h
See if one or more of the partitions is full, as in:
 /dev/vda1 236M 230M 0 100% /boot
anonymous2
  • 4,325
