-1
I cannt mountig to another part of my hdd which is windows10 and i lost my windows password....when i try to mount it to get my pictures which are saved there... the messege i get is:
Error mounting /dev/sda5 at /media/fareidon/Windows8_OS: Command-line `mount -t "ntfs" -o "uhelper=udisks2,nodev,nosuid,uid=1000,gid=1000" "/dev/sda5" "/media/fareidon/Windows8_OS"' exited with non-zero exit status 14: The disk contains an unclean file system (0, 0).
Metadata kept in Windows cache, refused to mount.
Failed to mount '/dev/sda5': Operasjonen er ikke tillatt
The NTFS partition is in an unsafe state. Please resume and shutdown
Windows fully (no hibernation or fast restarting), or mount the volume
read-only with the 'ro' mount option.
what shall i do it without the windows password..thanks for helping
i tried this comand sudo mount -t ntfs -o uhelper=udisks2,nodev,nosuid,uid=1000,gid=1000 /dev/sda5 /media/fareidon/Windows8_OS
but its ask me the password which i said i forgot it!
and tried this comand to:
mount /dev/sda5 /media/fareidon/windows8_os -o ro
the answer i get :
mount: only root can use"--options"optios
somebody can help,still i cannt mount,the big problem is the windows password!! when i comand any command,it ask me the password of windows which i forgott!!
You have to force mount it. And the command is already given... use it with sudo...
Final command :
You will need to enter your password, it wont be seen... Try it out...
We are Borg
  • 572
  • 22
The error message states the solution: Mount the volume read-only. As root, run something like the following command:
mount /dev/sda5 /media/fareidon/Windows8_OS -o ro
Note that the mount target (/media/fareidon/Windows8_OS) needs to exist.
antiguru
  • 215
