13
I have a string
00:28:04 /usr/lib/jvm/jre/bin/java -DJDBC_CONNECTION_STRING= -Dspring.profiles.active=qa -XX:MaxPermSize=256
and want to extract the word qa that follows -Dspring.profiles.active.
I have the string save in a file text.txt just to demo on it.
When I do
grep -r -o "spring.profiles.active=" text.txt
The result is spring.profiles.active=
This word does not always be qa, it could be prod or dev.
What I'd like to do is find the word spring.profiles.active and after the = extract that word.
I would like to shell script this because I use the word to configure other items on the server.
Is this possible and if so, how do I do it.
A.B.
  • 92,125
Gman
  • 491
You can use grep with PCRE (-P):
grep -Po 'spring.profiles.active=\K[^ ]+' <<<'.....string.....'
  • spring.profiles.active= will match this substring literally, \K will discard the match
  • [^ ]+ will select the desired portion i.e. the portion after spring.profiles.active=, till the next space
For a file:
grep -Po 'spring.profiles.active=\K[^ ]+' file.txt
Example:
% grep -Po 'spring.profiles.active=\K[^ ]+' <<<'00:28:04 /usr/lib/jvm/jre/bin/java -DJDBC_CONNECTION_STRING= -Dspring.profiles.active=qa -XX:MaxPermSize=256'
qa
sed would take similar logic:
sed -r 's/.*spring.profiles.active=([^ ]+).*/\1/' <<<'.....string.....'
Example:
% sed -r 's/.*spring.profiles.active=([^ ]+).*/\1/' <<<'00:28:04 /usr/lib/jvm/jre/bin/java -DJDBC_CONNECTION_STRING= -Dspring.profiles.active=qa -XX:MaxPermSize=256'
qa
Handling errors:
In your script you may want to handle the case where there is no match, in other words where your original string does not contain spring.profiles.active=. In the above sed example, you obtain the whole original string, which could create problems:
% var="$(sed -r 's/.*spring.profiles.active=([^ ]+).*/\1/' <<<'00:28:04 /usr/lib/jvm/jre/bin/java -DJDBC_CONNECTION_STRING= -XX:MaxPermSize=256')"
% echo $var
If you prefer to obtain the empty string when there is no match, add the -n option to the sed command and the p option to the sed s command, like this:
% var="$(sed -rn 's/.*spring.profiles.active=([^ ]+).*/\1/p' <<<'00:28:04 /usr/lib/jvm/jre/bin/java -DJDBC_CONNECTION_STRING= -XX:MaxPermSize=256')"
% echo $var
% var="$(sed -rn 's/.*spring.profiles.active=([^ ]+).*/\1/p' <<<'00:28:04 /usr/lib/jvm/jre/bin/java -DJDBC_CONNECTION_STRING= -Dspring.profiles.active=qa -XX:MaxPermSize=256')"
% echo $var
qa
Then you can test if $var is empty or not.
Law29
  • 135
heemayl
  • 93,925
Using awk
awk -F"-Dspring.profiles.active=" '{sub(/ .*/,"",$2);print $2}' <<<'your_string'
or
awk -F"-Dspring.profiles.active=" '{sub(/ .*/,"",$2);print $2}' your_file
Example
% awk -F"-Dspring.profiles.active=" '{sub(/ .*/,"",$2);print $2}' <<<'00:28:04 /usr/lib/jvm/jre/bin/java -DJDBC_CONNECTION_STRING= -Dspring.profiles.active=qa -XX:MaxPermSize=256'
qa
A.B.
  • 92,125
I'll throw a Perl one in the mix:
<<<'string' perl -lane '$F[3]=~s/.*?=//;print($F[3])'
  • -l: enables automatic line-ending processing. It has two separate effects. First, it automatically chomps $/ (the input record separator) when used with -n or -p. Second, it assigns $\ (the output record separator) to have the value of octnum so that any print statements will have that separator added back on. If octnum is omitted, sets $\ to the current value of $/.
  • -a: turns on autosplit mode when used with a -n or -p. An implicit split command to the @F array is done as the first thing inside the implicit while loop produced by the -n or -p.
  • n: causes Perl to assume the following loop around your program, which makes it iterate over filename arguments somewhat like sed -n or awk:
    LINE:
      while (<>) {
          ...             # your program goes here
  • -e: may be used to enter one line of program.
% <<<'00:28:04 /usr/lib/jvm/jre/bin/java -DJDBC_CONNECTION_STRING= -Dspring.profiles.active=qa -XX:MaxPermSize=256' perl -lane '$F[3]=~s/.*?=//;print($F[3])'
qa
kos
  • 41,268
