Is it possible to have bumblebee and primus 64 bit and 32 bit both installed at the same time? So that 64bit apps will use the 64bit libs?
If so, how?
When I sudo apt-get install primus:i386, it tells me it's going to remove the 64 bit versions.
Thanks!
UPDATE: Here's what I'm getting when I run: primerun steam or optirun steam Running Steam on ubuntu 15.10 64-bit STEAM_RUNTIME is enabled automatically Installing breakpad exception handler for appid(steam)/version(1446742416) assert_20151114115841_1.dmp[11632]: Uploading dump (out-of-process) /tmp/dumps/assert_20151114115841_1.dmp /home/me/.local/share/Steam/steam.sh: line 756: 11621 Segmentation fault (core dumped) $STEAM_DEBUGGER "$STEAMROOT/$STEAMEXEPATH" "$@" assert_20151114115841_1.dmp[11632]: Finished uploading minidump (out-of-process): success = yes assert_20151114115841_1.dmp[11632]: response: CrashID=bp-6292283e-e5e0-4d07-b211-bc29a2151114 assert_20151114115841_1.dmp[11632]: file ''/tmp/dumps/assert_20151114115841_1.dmp'', upload yes: ''CrashID=bp-6292283e-e5e0-4d07-b211-bc29a2151114''
Chemdream
  • 153
You shouldn't install primus:i386 but primus-libs:i386 and primus-libs-ia32:i386
Also installing primus alone should install those packages by default!
works for me with both 32-bit (Steam, TF2 etc.)
and 64-bit apps (Blender, War Thunder etc.)!
