An unresolved problem occurred while initializing the package information. It says I have a bug against the update manager package with this error message:
E:Malformed line 58 in source list/etc/apt/sources.list (distribution parse)
There's a syntax error in your sources.list, so checking for package updates is failing. You should either open your sources.list file and correct the error, or you can just reset your sources by following the instructions outlined here: https://askubuntu.com/a/192388/470880
Edit - If you'd like help correcting the issue in your existing sources.list file, run the following and copy and paste the contents of your sources file here:
sudo -H gedit /etc/apt/sources.list
