I 'm trying to install Wine on my Ubuntu system, but cannot complete the installation. I have read countless other Q & A but none of them seems to fix my problem. When I try to install it with
sudo apt-get install wine
I get this message:
wine : Depends: wine1.6 but it is not going to be installed
I tried with Synaptic: (wine package has an exclamation mark instead of a check)
Could not apply changes!
Fix broken packages first.
I click to fix the packages and then this error occurs:
E: Error, pkgProblemResolver::Resolve generated breaks, this may be caused by held packages.
E: Unable to correct dependencies
I have also tried commands like
sudo apt-get remove wine
sudo aptitude search wine
sudo dpkg -p Wine
but none of them worked as well. I 'm so confused right now that I might be missing something simple. I 'm a new Ubuntu user, so I don 't know advanced methods and terminal commands. Am I doing something wrong? I have only tried solutions and commands posted in this forum. Thanks in advance for the help!
Edit: After I ran
uname -a; lsb_release -a; apt-cache policy wine wine1.6; sudo apt-get remove wine; sudo apt-get install -f I get:
Linux tommy-Lenovo-Z50-75 3.19.0-33-generic #38~14.04.1-Ubuntu SMP Fri Nov 6 18:17:28 UTC 2015 x86_64 x86_64 x86_64 GNU/Linux
lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description:    Ubuntu 14.04.3 LTS
Release:    14.04
Codename:   trusty
wine:
  Installed: (none)
  Candidate: 1:1.7.50-0ubuntu1
  Version table:
     1:1.7.50-0ubuntu1 0
        500 http://ppa.launchpad.net/ubuntu-wine/ppa/ubuntu/ trusty/main amd64 Packages
     1:1.6.2-0ubuntu4 0
        500 http://archive.ubuntu.com/ubuntu/ trusty/universe amd64 Packages
wine1.6:
  Installed: (none)
  Candidate: 1:1.6.2-0ubuntu4
  Version table:
     1:1.6.2-0ubuntu4 0
Building dependency tree
Package 'wine' is not installed, so not removed
0 upgraded, 0 newly installed, 0 to remove and 3 not upgraded.
Reading package lists... Done
Edit: I tried
$ sudo apt-get remove --purge wine
$ sudo apt-get install wine
even after running sudo apt-get update. The problem remains.
Edit (last and final): After an unsuccessful attempt to determine the broken packages, I will format my laptop to Ubuntu Gnome (latest version). Current version I run 14.04 LTS with Unity. Thanks for all your help, this thread should be closed. It seems my system is missing some packages so since it is freshly installed (2 weeks ago) I will just format it again. Thanks again for all the responses!
Type the following into a terminal:
This should remove any held packages, and properly install Wine. Also make sure that you did not install Wine from source.
  1. You currently do not have any problem ... proved by :
    $ sudo apt-get install -f
  2. The PPA also does not have problems. There is a package wine for Trusty and this should install the package wine1.7 Check it with this link. As having tested this on my machine it works. The package wine forces the installation of wine1.7. I'm afraid you just forgot to run the command sudo apt-get update. Obviously you did it in the meantime (according to your updated question).
  3. The package wine is "only" a meta-package. You could also install wine with the command
    sudo apt-get install wine1.7
cl-netbox
  • 31,491
A.B.
  • 92,125
This would repair the necessary links too.
> sudo apt-get install wine --fix-missing
dschinn1001
  • 3,863
