Despite Chromium being set as my preferred web browser under "System Info", when I click a link in an IM window of Pidgin, it opens in Firefox. How do I make it so that links open in Chromium?
I am running:
  • Ubuntu 11.10
  • chromium-browser 14.0.835.202~r103287-0ubuntu1
  • pidgin 1:2.10.0-0ubuntu2
EDIT:
I also tried sudo update-alternatives --config x-www-browser and selected chromium (in both auto and manual mode), but after running sensible-browser & it still loads Firefox.
Chromium is also set to the default browser within the Chromium -> Preferences -> Default Browser panel.
Kris Harper
  • 13,705
paniwani
  • 295
If you are on a gnome system, gnome-www-browser is checked before x-www-browser, so you might have more luck changing this alternative with
sudo update-alternatives --config gnome-www-browser
chaskes
  • 15,536
a first suggestion would be to manually check your preferences by editing the file
~/.purple/prefs.xml
there you can find the following lines (in the tag pidgin => browsers:
<pref name='browser' type='string' value='custom'/>
<pref name='place' type='int' value='0'/>
<pref name='manual_command' type='string' value='sensible-browser'/>
I suggest you to have those three lines like they are given in my example.
If this is correct, you should try to run:
sensible-browser &
from a shell to see whether your preferred browser is setup correctly.
vdmit
Michael K
  • 14,338
When I installed and set my default browser to Chrome stable, sensible-browser & opened up Chrome correctly.
It must have just been an issue with Chromium.
paniwani
  • 295
