My computer is very unstable while running Ubuntu 14.04.2 or upper (anything newer than kernel 3.13) with only a VNC viewer in a sort of kiosk mode, it freezes frequently having to do a hard reset many times a day. As shown in this related bug it appears to be a problem with the intel i915 kernel module on Bay Trail systems and there is no workaround, even on newer kernels.
I don't need any 3D nor hardware acceleration, so how can I disable the intel i915 sound and video drivers and use a VESA / framebuffer generic one or something simpler? Is it possible to do this? I just want to be sure that the modules are not loaded and still run a simple X11 apps.
I tried adding this to a file in /etc/modprobe.d/ file and updating initramfs:
blacklist i915
blacklist snd_hda_intel
But /var/log/Xorg.0.log still shows that it is loading them:
[323589.490] (II) LoadModule: "intel"
[323589.491] (II) Loading /usr/lib/xorg/modules/drivers/intel_drv.so
[323589.516] (II) Module intel: vendor="X.Org Foundation"
[323589.554] (II) intel(G0): Using Kernel Mode Setting driver: i915, version 1.6.0 20150522
[323589.554] (II) intel(G0): SNA compiled: xserver-xorg-video-intel 2:2.99.917+git20150808-0ubuntu4 (Robert Ancell <robert.ancell@canonical.com>)
[323589.554] (II) intel(G0): SNA compiled for use with valgrind
[323589.555] (II) intel: Driver for Intel(R) Integrated Graphics Chipsets:
[323589.556] (II) intel: Driver for Intel(R) HD Graphics: 2000-6000
[323589.556] (II) intel: Driver for Intel(R) Iris(TM) Graphics: 5100, 6100
[323589.556] (II) intel: Driver for Intel(R) Iris(TM) Pro Graphics: 5200, 6200, P6300
fmaste
  • 51
I was struggling for days to make such setup. When I gave up, my machine boots to X only with just one screen (I have 2 connected). It is really running on VESA mode.
$ sudo lshw -c display
  *-display UNCLAIMED
       description: VGA compatible controller
       product: 3rd Gen Core processor Graphics Controller
       vendor: Intel Corporation
       physical id: 2
       bus info: pci@0000:00:02.0
       version: 09
       width: 64 bits
       clock: 33MHz
       capabilities: msi pm vga_controller bus_master cap_list
       configuration: latency=0
       resources: memory:f6400000-f67fffff memory:e0000000-efffffff ioport:f000(size=64)
$ xrandr --verbose
xrandr: Failed to get size of gamma for output default
Screen 0: minimum 1366 x 768, current 1366 x 768, maximum 1366 x 768
default connected 1366x768+0+0 (0x270) normal (normal) 0mm x 0mm
    Identifier: 0x26f
    Timestamp:  34274
    Subpixel:   unknown
    Clones:
    CRTC:       0
    CRTCs:      0
    Transform:  1.000000 0.000000 0.000000
                0.000000 1.000000 0.000000
                0.000000 0.000000 1.000000
               filter:
  1366x768 (0x270) 79.731MHz *current
        h: width  1366 start    0 end    0 total 1366 skew    0 clock  58.37KHz
        v: height  768 start    0 end    0 total  768           clock  76.00Hz
$ find /dev/ -iname "fb*"
/dev/fb0
$ udevadm info -a /dev/fb0
Udevadm info starts with the device specified by the devpath and then
walks up the chain of parent devices. It prints for every device
found, all possible attributes in the udev rules key format.
A rule to match, can be composed by the attributes of the device
and the attributes from one single parent device.
  looking at device '/devices/platform/vesa-framebuffer.0/graphics/fb0':
    KERNEL=="fb0"
    SUBSYSTEM=="graphics"
    DRIVER==""
    ATTR{bits_per_pixel}=="32"
    ATTR{blank}==""
    ATTR{console}==""
    ATTR{cursor}==""
    ATTR{mode}==""
    ATTR{modes}=="U:1366x768p-76"
    ATTR{name}=="VESA VGA"
    ATTR{pan}=="0,0"
    ATTR{rotate}=="0"
    ATTR{state}=="0"
    ATTR{stride}=="5504"
    ATTR{virtual_size}=="1366,768"
  looking at parent device '/devices/platform/vesa-framebuffer.0':
    KERNELS=="vesa-framebuffer.0"
    SUBSYSTEMS=="platform"
    DRIVERS=="vesa-framebuffer"
    ATTRS{driver_override}=="(null)"
  looking at parent device '/devices/platform':
    KERNELS=="platform"
    SUBSYSTEMS==""
    DRIVERS==""
Not sure yet for all things needed to make so, but here I remember:
  1. Locate i915 driver file and delete it
    sudo updatedb
    locate i915.ko
    sudo mv /.../i915.ko ~/i915.ko.backup
  2. Update RAMDisk
    sudo update-initramfs
  3. Reboot
Notes:
  • Install xdm if not already installed and you need a display manager. lightdm may fail ot start.
  • Remove any old xrandr command from .xprofile and .xsessionrc if you have set one. Because it will fail as you see the above xrandr outputs and block the session start up.
user.dz
  • 49,176
I HAVE DEFEATED THE HANG UPS ON THE VIDEO gksudo xed /etc/default/grub Add intel_idle.max_cstate=1 to the GRUB_CMDLINE_LINUX_DEFAULT= line. EXAMPLE: GRUB_CMDLINE_LINUX_DEFAULT="intel_idle.max_cstate=1"
