I have a network printer at 192.168.2.101 that I can reach just fine with other machines on my network (ping and access the printer web server). For some reason I can't access the printer from my Ubuntu machine--pings return host unreachable.
I'm running Ubuntu 11.04
ifconfig
eth1      Link encap:Ethernet  HWaddr 38:59:f9:c4:52:a9
          inet addr:192.168.2.11  Bcast:192.168.2.255  Mask:255.255.255.0
          inet6 addr: fe80::3a59:f9ff:fec4:52a9/64 Scope:Link
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:167828 errors:0 dropped:0 overruns:0 frame:2000398
          TX packets:116132 errors:16 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:213283954 (213.2 MB)  TX bytes:15552076 (15.5 MB)
          Interrupt:16
Edited Oct/20/2011
I've added the requested diagnostics below. Any hints in here?
ip route show
$ ip route show
192.168.2.0/24 dev eth1  proto kernel  scope link  src 192.168.2.11  metric 2
169.254.0.0/16 dev eth1  scope link  metric 1000
default via 192.168.2.1 dev eth1  proto static
traceroute
$ ip route show
netstat
$ netstat -rn
Kernel IP routing table
Destination     Gateway         Genmask         Flags   MSS Window  irtt Iface
192.168.2.0     0.0.0.0         255.255.255.0   U         0 0          0 eth1
169.254.0.0     0.0.0.0         255.255.0.0     U         0 0          0 eth1
0.0.0.0         192.168.2.1     0.0.0.0         UG        0 0          0 eth1
Edited Nov/2/2011
After a bit more digging it appears this might be an issue with MAC address translation.
arp yeilds
$ arp
Address                  HWtype  HWaddress           Flags Mask            Iface
192.168.2.101                    (incomplete)                              eth1
192.168.2.1              ether   00:17:3f:90:cd:93   C                     eth1
I've tried adding a static entry, per this post Add static ARP entries when network is brought up, but the result is the same.
Any thoughts?
The output of netstat -rn should show something like:
$ netstat -rn
0.0.0.0         192.168.100.1   0.0.0.0         UG        0 0          0 eth0
169.254.0.0     0.0.0.0         255.255.0.0     U         0 0          0 eth0
192.168.100.0   0.0.0.0         255.255.255.0   U         0 0          0 eth0
You should have all 3 lines - a default route, a link local route, and a local subnet route.
waltinator
  • 37,856
I have the same problem today. Check the mac address of your Ubuntu machine and printer, they have a same mac address, so change your Ubuntu mac address to fix this problem.
