This is my xorg.conf file:
Section "Screen"
Identifier "Screen0"
Device "Device0"
Monitor "Montior0"
DefaultDepth 24
Subsection "Display"
Depth 24
Modes "1024 x 768" "1280 x 960" "1366 x 768" "1280 x 1024" "1440 x 900" "1440 x 960" "1440 x 1080" "1600 x 1200" "1920 x 1080" "1920 x 1200"
EndSubsection
EndSection
Section "Monitor"
VendorName "Monitor0"
ModelName "Model0"
HorizSync 30 - 300
VertRefresh 30 - 500
EndSection
Modeline "1440x1080_60.00" 129.00 1440 1528 1680 1920 1080 1083 1087 1120 -hsync +vsync
When I reboot my PC, I find that I'm unable to get a graphical login.
The error I get is along the lines of:
Error in xorg.conf
This section must have an Identifier line.
EE problem/error parsing the config line
Fatal server error: no screens found
What's the reason for this and how can solve it?
All questions on this have no solutions...
Output of /var/log/Xorg.0.log:
[ 34.304]
X.Org X Server 1.15.1
Release Date: 2014-04-13
[ 34.304] X Protocol Version 11, Revision 0
[ 34.304] Build Operating System: Linux 3.2.0-76-generic x86_64 Ubuntu
[ 34.304] Current Operating System: Linux pointcarre-OptiPlex-755 3.13.0-24-generic #47-Ubuntu SMP Fri May 2 23:30:00 UTC 2014 x86_64
[ 34.304] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.13.0-24-generic root=UUID=94e3a36a-e676-4f71-b4fd-1edcc90700da ro quiet splash
[ 34.304] Build Date: 12 February 2015 02:49:29PM
[ 34.304] xorg-server 2:1.15.1-0ubuntu2.7 (For technical support please see http://www.ubuntu.com/support)
[ 34.304] Current version of pixman: 0.30.2
[ 34.304] Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
[ 34.304] Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 34.304] (==) Log file: "/var/log/Xorg.0.log", Time: Fri Nov 13 21:00:30 2015
[ 34.390] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 34.427] (==) No Layout section. Using the first Screen section.
[ 34.427] (==) No screen section available. Using defaults.
[ 34.427] (**) |-->Screen "Default Screen Section" (0)
[ 34.427] (**) | |-->Monitor ""
[ 34.427] (==) No monitor specified for screen "Default Screen Section".
Using a default monitor configuration.
[ 34.427] (==) Automatically adding devices
[ 34.427] (==) Automatically enabling devices
[ 34.427] (==) Automatically adding GPU devices
[ 34.427] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[ 34.427] Entry deleted from font path.
[ 34.427] (WW) The directory "/usr/share/fonts/X11/100dpi/" does not exist.
[ 34.427] (WW) The directory "/usr/share/fonts/X11/75dpi/" does not exist.
[ 34.427] (WW) The directory "/usr/share/fonts/X11/100dpi" does not exist.
[ 34.427] (WW) The directory "/usr/share/fonts/X11/75dpi" does not exist.
[ 34.428] (==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
built-ins
[ 34.428] (==) ModulePath set to "/usr/lib/x86_64-linux-gnu/xorg/extra-modules,/usr/lib/xorg/extra-modules,/usr/lib/xorg/modules"
[ 34.428] (II) The server relies on udev to provide the list of input devices.
If no devices become available, reconfigure udev or disable AutoAddDevices.
[ 34.428] (II) Loader magic: 0x7f4070706d40
[ 34.428] (II) Module ABI versions:
[ 34.428] X.Org ANSI C Emulation: 0.4
[ 34.428] X.Org Video Driver: 15.0
[ 34.428] X.Org XInput driver : 20.0
[ 34.428] X.Org Server Extension : 8.0
[ 34.428] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 34.429] (--) PCI:*(0:1:0:0) 10de:0a65:1043:848f rev 162, Mem @ 0xfd000000/16777216, 0xc0000000/268435456, 0xd0000000/33554432, I/O @ 0x0000dc80/128, BIOS @ 0x????????/524288
[ 34.429] Initializing built-in extension Generic Event Extension
[ 34.429] Initializing built-in extension SHAPE
[ 34.429] Initializing built-in extension MIT-SHM
[ 34.429] Initializing built-in extension XInputExtension
[ 34.429] Initializing built-in extension XTEST
[ 34.429] Initializing built-in extension BIG-REQUESTS
[ 34.429] Initializing built-in extension SYNC
[ 34.429] Initializing built-in extension XKEYBOARD
[ 34.429] Initializing built-in extension XC-MISC
[ 34.430] Initializing built-in extension SECURITY
[ 34.430] Initializing built-in extension XINERAMA
[ 34.430] Initializing built-in extension XFIXES
[ 34.430] Initializing built-in extension RENDER
[ 34.430] Initializing built-in extension RANDR
[ 34.430] Initializing built-in extension COMPOSITE
[ 34.430] Initializing built-in extension DAMAGE
[ 34.430] Initializing built-in extension MIT-SCREEN-SAVER
[ 34.430] Initializing built-in extension DOUBLE-BUFFER
[ 34.430] Initializing built-in extension RECORD
[ 34.430] Initializing built-in extension DPMS
[ 34.430] Initializing built-in extension Present
[ 34.430] Initializing built-in extension DRI3
[ 34.430] Initializing built-in extension X-Resource
[ 34.430] Initializing built-in extension XVideo
[ 34.430] Initializing built-in extension XVideo-MotionCompensation
[ 34.430] Initializing built-in extension SELinux
[ 34.430] Initializing built-in extension XFree86-VidModeExtension
[ 34.430] Initializing built-in extension XFree86-DGA
[ 34.430] Initializing built-in extension XFree86-DRI
[ 34.430] Initializing built-in extension DRI2
[ 34.430] (WW) "glamoregl" will not be loaded unless you've specified it to be loaded elsewhere.
[ 34.430] (II) "glx" will be loaded by default.
[ 34.430] (WW) "xmir" is not to be loaded by default. Skipping.
[ 34.430] (II) LoadModule: "glx"
[ 34.430] (II) Loading /usr/lib/x86_64-linux-gnu/xorg/extra-modules/libglx.so
[ 34.456] (II) Module glx: vendor="NVIDIA Corporation"
[ 34.456] compiled for 4.0.2, module version = 1.0.0
[ 34.456] Module class: X.Org Server Extension
[ 34.456] (II) NVIDIA GLX Module 340.93 Wed Aug 19 16:23:51 PDT 2015
[ 34.456] Loading extension GLX
[ 34.456] (==) Matched nvidia as autoconfigured driver 0
[ 34.456] (==) Matched nouveau as autoconfigured driver 1
[ 34.456] (==) Matched nvidia as autoconfigured driver 2
[ 34.456] (==) Matched nouveau as autoconfigured driver 3
[ 34.456] (==) Matched modesetting as autoconfigured driver 4
[ 34.456] (==) Matched fbdev as autoconfigured driver 5
[ 34.456] (==) Matched vesa as autoconfigured driver 6
[ 34.456] (==) Assigned the driver to the xf86ConfigLayout
[ 34.456] (II) LoadModule: "nvidia"
[ 34.456] (II) Loading /usr/lib/x86_64-linux-gnu/xorg/extra-modules/nvidia_drv.so
[ 34.457] (II) Module nvidia: vendor="NVIDIA Corporation"
[ 34.457] compiled for 4.0.2, module version = 1.0.0
[ 34.457] Module class: X.Org Video Driver
[ 34.457] (II) LoadModule: "nouveau"
[ 34.457] (II) Loading /usr/lib/xorg/modules/drivers/nouveau_drv.so
[ 34.472] (II) Module nouveau: vendor="X.Org Foundation"
[ 34.472] compiled for 1.15.0, module version = 1.0.10
[ 34.472] Module class: X.Org Video Driver
[ 34.473] ABI class: X.Org Video Driver, version 15.0
[ 34.473] (II) LoadModule: "modesetting"
[ 34.473] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 34.473] (II) Module modesetting: vendor="X.Org Foundation"
[ 34.473] compiled for 1.15.0, module version = 0.8.1
[ 34.473] Module class: X.Org Video Driver
[ 34.473] (II) LoadModule: "fbdev"
[ 34.473] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
[ 34.473] (II) Module fbdev: vendor="X.Org Foundation"
[ 34.473] compiled for 1.15.0, module version = 0.4.4
[ 34.473] (II) LoadModule: "vesa"
[ 34.474] (II) Loading /usr/lib/xorg/modules/drivers/vesa_drv.so
[ 34.474] (II) Module vesa: vendor="X.Org Foundation"
[ 34.474] compiled for 1.15.0, module version = 2.3.3
[ 34.474] Module class: X.Org Video Driver
[ 34.474] ABI class: X.Org Video Driver, version 15.0
[ 34.474] (II) NVIDIA dlloader X Driver 340.93 Wed Aug 19 16:01:53 PDT 2015
[ 34.474] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 34.474] (II) NOUVEAU driver Date: Thu Nov 7 14:56:48 2013 +1000
[ 34.474] (II) NOUVEAU driver for NVIDIA chipset families :
[ 34.474] RIVA TNT (NV04)
[ 34.474] RIVA TNT2 (NV05)
[ 34.474] GeForce 256 (NV10)
[ 34.474] GeForce 2 (NV11, NV15)
[ 34.474] GeForce 4MX (NV17, NV18)
[ 34.474] GeForce 3 (NV20)
[ 34.474] GeForce 4Ti (NV25, NV28)
[ 34.474] GeForce FX (NV3x)
[ 34.474] GeForce 6 (NV4x)
[ 34.474] GeForce 7 (G7x)
[ 34.474] GeForce 8 (G8x)
[ 34.474] GeForce GTX 200 (NVA0)
[ 34.474] GeForce GTX 400 (NVC0)
[ 34.474] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 34.474] (II) FBDEV: driver for framebuffer: fbdev
[ 34.474] (II) VESA: driver for VESA chipsets: vesa
[ 34.474] (++) using VT number 8
[ 34.477] (II) Loading sub module "fb"
[ 34.477] (II) LoadModule: "fb"
[ 34.532] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 34.532] (II) Module fb: vendor="X.Org Foundation"
[ 34.532] compiled for 1.15.1, module version = 1.0.0
[ 34.532] ABI class: X.Org ANSI C Emulation, version 0.4
[ 34.532] (WW) Unresolved symbol: fbGetGCPrivateKey
[ 34.532] (II) Loading sub module "wfb"
[ 34.532] (II) LoadModule: "wfb"
[ 34.533] (II) Loading /usr/lib/xorg/modules/libwfb.so
[ 34.533] (II) Module wfb: vendor="X.Org Foundation"
[ 34.533] compiled for 1.15.1, module version = 1.0.0
[ 34.533] ABI class: X.Org ANSI C Emulation, version 0.4
[ 34.533] (II) Loading sub module "ramdac"
[ 34.533] (II) LoadModule: "ramdac"
[ 34.533] (II) Module "ramdac" already built-in
[ 34.533] (WW) Falling back to old probe method for modesetting
[ 34.534] (WW) Falling back to old probe method for fbdev
[ 34.534] (II) Loading sub module "fbdevhw"
[ 34.534] (II) LoadModule: "fbdevhw"
[ 34.534] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[ 34.534] (II) Module fbdevhw: vendor="X.Org Foundation"
[ 34.534] compiled for 1.15.1, module version = 0.0.2
[ 34.534] ABI class: X.Org Video Driver, version 15.0
[ 34.534] (EE) open /dev/fb0: No such file or directory
[ 34.534] (WW) Falling back to old probe method for vesa
[ 34.534] (II) NVIDIA(0): Creating default Display subsection in Screen section
"Default Screen Section" for depth/fbbpp 24/32
[ 34.534] (==) NVIDIA(0): Depth 24, (==) framebuffer bpp 32
[ 34.534] (==) NVIDIA(0): RGB weight 888
[ 34.534] (==) NVIDIA(0): Default visual is TrueColor
[ 34.534] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[ 34.534] (**) NVIDIA(0): Enabling 2D acceleration
[ 35.126] (II) NVIDIA(0): Display (Samsung SyncMaster (DFP-0)) does not support NVIDIA
[ 35.126] (II) NVIDIA(0): 3D Vision stereo.
[ 35.126] (II) NVIDIA(GPU-0): Found DRM driver nvidia-drm (20150116)
[ 35.127] (II) NVIDIA(0): NVIDIA GPU GeForce 210 (GT218) at PCI:1:0:0 (GPU-0)
[ 35.127] (--) NVIDIA(0): Memory: 1048576 kBytes
[ 35.127] (--) NVIDIA(0): VideoBIOS: 70.18.64.00.05
[ 35.127] (II) NVIDIA(0): Detected PCI Express Link width: 16X
[ 35.129] (--) NVIDIA(0): Valid display device(s) on GeForce 210 at PCI:1:0:0
[ 35.129] (--) NVIDIA(0): CRT-0
[ 35.129] (--) NVIDIA(0): CRT-1
[ 35.129] (--) NVIDIA(0): Samsung SyncMaster (DFP-0) (boot, connected)
[ 35.129] (--) NVIDIA(0): DFP-1
[ 35.129] (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[ 35.129] (--) NVIDIA(GPU-0): CRT-1: 400.0 MHz maximum pixel clock
[ 35.129] (--) NVIDIA(0): Samsung SyncMaster (DFP-0): Internal TMDS
[ 35.129] (--) NVIDIA(GPU-0): Samsung SyncMaster (DFP-0): 330.0 MHz maximum pixel clock
[ 35.129] (--) NVIDIA(0): DFP-1: Internal TMDS
[ 35.129] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[ 35.129] (**) NVIDIA(0): Using HorizSync/VertRefresh ranges from the EDID for display
[ 35.129] (**) NVIDIA(0): device Samsung SyncMaster (DFP-0) (Using EDID frequencies
[ 35.129] (**) NVIDIA(0): has been enabled on all display devices.)
[ 35.132] (==) NVIDIA(0):
[ 35.132] (==) NVIDIA(0): No modes were requested; the default mode "nvidia-auto-select"
[ 35.132] (==) NVIDIA(0): will be used as the requested mode.
[ 35.132] (II) NVIDIA(0): Validated MetaModes:
[ 35.132] (II) NVIDIA(0): "DFP-0:nvidia-auto-select"
[ 35.132] (II) NVIDIA(0): Virtual screen size determined to be 1280 x 1024
[ 35.156] (--) NVIDIA(0): DPI set to (95, 96); computed from "UseEdidDpi" X config
[ 35.156] (--) NVIDIA(0): option
[ 35.156] (II) UnloadModule: "nouveau"
[ 35.156] (II) Unloading nouveau
[ 35.156] (II) UnloadModule: "modesetting"
[ 35.156] (II) Unloading modesetting
[ 35.156] (II) UnloadModule: "fbdev"
[ 35.157] (II) Unloading fbdev
[ 35.157] (II) UnloadSubModule: "fbdevhw"
[ 35.157] (II) Unloading fbdevhw
[ 35.157] (II) UnloadModule: "vesa"
[ 35.157] (II) Unloading vesa
[ 35.157] (--) Depth 24 pixmap format is 32 bpp
[ 35.157] (II) NVIDIA: Using 768.00 MB of virtual memory for indirect memory access.
[ 35.161] (II) NVIDIA(0): Setting mode "DFP-0:nvidia-auto-select"
[ 35.212] Loading extension NV-GLX
[ 35.237] (==) NVIDIA(0): Disabling shared memory pixmaps
[ 35.237] (==) NVIDIA(0): Backing store enabled
[ 35.237] (==) NVIDIA(0): Silken mouse enabled
[ 35.237] (==) NVIDIA(0): DPMS enabled
[ 35.237] Loading extension NV-CONTROL
[ 35.238] Loading extension XINERAMA
[ 35.238] (II) Loading sub module "dri2"
[ 35.238] (II) LoadModule: "dri2"
[ 35.238] (II) Module "dri2" already built-in
[ 35.238] (II) NVIDIA(0): [DRI2] Setup complete
[ 35.238] (II) NVIDIA(0): [DRI2] VDPAU driver: nvidia
[ 35.238] (--) RandR disabled
[ 35.244] (II) SELinux: Disabled on system
[ 35.245] (II) Initializing extension GLX
[ 35.261] (II) XKB: reuse xkmfile /var/lib/xkb/server-B20D7FC79C7F597315E3E501AEF10E0D866E8E92.xkm
[ 35.265] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[ 35.265] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 35.265] (II) LoadModule: "evdev"
[ 35.265] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[ 35.285] (II) Module evdev: vendor="X.Org Foundation"
[ 35.285] compiled for 1.15.0, module version = 2.8.2
[ 35.285] Module class: X.Org XInput Driver
[ 35.285] ABI class: X.Org XInput driver, version 20.0
[ 35.285] (II) Using input driver 'evdev' for 'Power Button'
[ 35.285] (**) Power Button: always reports core events
[ 35.285] (**) evdev: Power Button: Device: "/dev/input/event1"
[ 35.285] (--) evdev: Power Button: Vendor 0 Product 0x1
[ 35.285] (--) evdev: Power Button: Found keys
[ 35.285] (II) evdev: Power Button: Configuring as keyboard
[ 35.285] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input1/event1"
[ 35.285] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[ 35.285] (**) Option "xkb_rules" "evdev"
[ 35.285] (**) Option "xkb_model" "pc105"
[ 35.285] (**) Option "xkb_layout" "gb"
[ 35.287] (II) XKB: reuse xkmfile /var/lib/xkb/server-2B4266AA55228AE7D9557A18F1965DBA19850816.xkm
[ 35.288] (II) config/udev: Adding input device Power Button (/dev/input/event0)
[ 35.288] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 35.288] (II) Using input driver 'evdev' for 'Power Button'
[ 35.288] (**) Power Button: always reports core events
[ 35.288] (**) evdev: Power Button: Device: "/dev/input/event0"
[ 35.288] (--) evdev: Power Button: Vendor 0 Product 0x1
[ 35.288] (--) evdev: Power Button: Found keys
[ 35.288] (II) evdev: Power Button: Configuring as keyboard
[ 35.288] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/device:00/PNP0C0C:00/input/input0/event0"
[ 35.288] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 7)
[ 35.288] (**) Option "xkb_rules" "evdev"
[ 35.288] (**) Option "xkb_model" "pc105"
[ 35.288] (**) Option "xkb_layout" "gb"
[ 35.288] (II) config/udev: Adding drm device (/dev/dri/card0) card0 /sys/devices/pci0000:00/0000:00:01.0/0000:01:00.0/drm/card0
[ 35.288] (II) config/udev: Ignoring already known drm device (/dev/dri/card0)
[ 35.289] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event12)
[ 35.289] (II) No input driver specified, ignoring this device.
[ 35.289] (II) This device may have been added with another device file.
[ 35.289] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=7 (/dev/input/event11)
[ 35.290] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=8 (/dev/input/event10)
[ 35.290] (II) No input driver specified, ignoring this device.
[ 35.290] (II) This device may have been added with another device file.
[ 35.290] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=9 (/dev/input/event9)
[ 35.290] (II) config/udev: Adding input device HDA Intel Line Out (/dev/input/event6)
[ 35.291] (II) config/udev: Adding input device HDA Intel Front Headphone (/dev/input/event5)
[ 35.291] (II) No input driver specified, ignoring this device.
[ 35.291] (II) This device may have been added with another device file.
[ 35.291] (II) config/udev: Adding input device HDA Intel Mic (/dev/input/event8)
[ 35.291] (II) config/udev: Adding input device HDA Intel Line (/dev/input/event7)
[ 35.292] (II) config/udev: Adding input device USB OPTICAL MOUSE (/dev/input/event2)
[ 35.292] (**) USB OPTICAL MOUSE: Applying InputClass "evdev pointer catchall"
[ 35.292] (II) Using input driver 'evdev' for 'USB OPTICAL MOUSE'
[ 35.292] (**) USB OPTICAL MOUSE: always reports core events
[ 35.292] (**) evdev: USB OPTICAL MOUSE: Device: "/dev/input/event2"
[ 35.292] (--) evdev: USB OPTICAL MOUSE: Vendor 0x93a Product 0x2516
[ 35.292] (--) evdev: USB OPTICAL MOUSE: Found 3 mouse buttons
[ 35.292] (--) evdev: USB OPTICAL MOUSE: Found scroll wheel(s)
[ 35.292] (--) evdev: USB OPTICAL MOUSE: Found relative axes
[ 35.292] (--) evdev: USB OPTICAL MOUSE: Found x and y relative axes
[ 35.292] (II) evdev: USB OPTICAL MOUSE: Configuring as mouse
[ 35.292] (II) evdev: USB OPTICAL MOUSE: Adding scrollwheel support
[ 35.292] (**) evdev: USB OPTICAL MOUSE: YAxisMapping: buttons 4 and 5
[ 35.292] (**) evdev: USB OPTICAL MOUSE: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[ 35.292] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.2/usb7/7-1/7-1:1.0/input/input5/event2"
[ 35.292] (II) XINPUT: Adding extended input device "USB OPTICAL MOUSE" (type: MOUSE, id 8)
[ 35.292] (II) evdev: USB OPTICAL MOUSE: initialized for relative axes.
[ 35.292] (**) USB OPTICAL MOUSE: (accel) keeping acceleration scheme 1
[ 35.292] (**) USB OPTICAL MOUSE: (accel) acceleration profile 0
[ 35.292] (**) USB OPTICAL MOUSE: (accel) acceleration factor: 2.000
[ 35.292] (**) USB OPTICAL MOUSE: (accel) acceleration threshold: 4
[ 35.293] (II) config/udev: Adding input device USB OPTICAL MOUSE (/dev/input/mouse0)
[ 35.293] (II) No input driver specified, ignoring this device.
[ 35.293] (II) This device may have been added with another device file.
[ 35.293] (II) config/udev: Adding input device Chicony USB Keyboard (/dev/input/event3)
[ 35.293] (**) Chicony USB Keyboard: Applying InputClass "evdev keyboard catchall"
[ 35.293] (II) Using input driver 'evdev' for 'Chicony USB Keyboard'
[ 35.293] (**) Chicony USB Keyboard: always reports core events
[ 35.293] (**) evdev: Chicony USB Keyboard: Device: "/dev/input/event3"
[ 35.293] (--) evdev: Chicony USB Keyboard: Vendor 0x4f2 Product 0x402
[ 35.293] (--) evdev: Chicony USB Keyboard: Found keys
[ 35.293] (II) evdev: Chicony USB Keyboard: Configuring as keyboard
[ 35.293] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.2/usb7/7-2/7-2:1.0/input/input6/event3"
[ 35.293] (II) XINPUT: Adding extended input device "Chicony USB Keyboard" (type: KEYBOARD, id 9)
[ 35.293] (**) Option "xkb_rules" "evdev"
[ 35.293] (**) Option "xkb_model" "pc105"
[ 35.293] (**) Option "xkb_layout" "gb"
[ 35.294] (II) config/udev: Adding input device Chicony USB Keyboard (/dev/input/event4)
[ 35.294] (**) Chicony USB Keyboard: Applying InputClass "evdev keyboard catchall"
[ 35.294] (II) Using input driver 'evdev' for 'Chicony USB Keyboard'
[ 35.294] (**) Chicony USB Keyboard: always reports core events
[ 35.294] (**) evdev: Chicony USB Keyboard: Device: "/dev/input/event4"
[ 35.294] (--) evdev: Chicony USB Keyboard: Vendor 0x4f2 Product 0x402
[ 35.294] (--) evdev: Chicony USB Keyboard: Found keys
[ 35.294] (II) evdev: Chicony USB Keyboard: Configuring as keyboard
[ 35.294] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.2/usb7/7-2/7-2:1.1/input/input7/event4"
[ 35.294] (II) XINPUT: Adding extended input device "Chicony USB Keyboard" (type: KEYBOARD, id 10)
[ 35.294] (**) Option "xkb_rules" "evdev"
[ 35.294] (**) Option "xkb_model" "pc105"
[ 35.294] (**) Option "xkb_layout" "gb"
[ 111.577] (II) NVIDIA(GPU-0): Display (Samsung SyncMaster (DFP-0)) does not support NVIDIA
[ 111.577] (II) NVIDIA(GPU-0): 3D Vision stereo.
[ 117.074] (II) NVIDIA(GPU-0): Display (Samsung SyncMaster (DFP-0)) does not support NVIDIA
[ 117.074] (II) NVIDIA(GPU-0): 3D Vision stereo.
[ 117.811] (II) NVIDIA(GPU-0): Display (Samsung SyncMaster (DFP-0)) does not support NVIDIA
[ 117.811] (II) NVIDIA(GPU-0): 3D Vision stereo.
[ 118.912] (II) XKB: reuse xkmfile /var/lib/xkb/server-7996F6726817F73651B9DE0FDA11E35FC4524568.xkm
[ 119.477] (II) XKB: reuse xkmfile /var/lib/xkb/server-F4830027FD6DFAF7D5CB4AF430AE062CB8989800.xkm
[ 139.935] (II) NVIDIA(GPU-0): Display (Samsung SyncMaster (DFP-0)) does not support NVIDIA
[ 139.935] (II) NVIDIA(GPU-0): 3D Vision stereo.
[ 150.687] (II) XKB: reuse xkmfile /var/lib/xkb/server-F4830027FD6DFAF7D5CB4AF430AE062CB8989800.xkm
[ 150.691] (II) XKB: reuse xkmfile /var/lib/xkb/server-F4830027FD6DFAF7D5CB4AF430AE062CB8989800.xkm
[ 150.695] (II) XKB: reuse xkmfile /var/lib/xkb/server-F4830027FD6DFAF7D5CB4AF430AE062CB8989800.xkm
[ 150.698] (II) XKB: reuse xkmfile /var/lib/xkb/server-F4830027FD6DFAF7D5CB4AF430AE062CB8989800.xkm
[ 150.702] (II) XKB: reuse xkmfile /var/lib/xkb/server-F4830027FD6DFAF7D5CB4AF430AE062CB8989800.xkm
[ 150.706] (II) XKB: reuse xkmfile /var/lib/xkb/server-F4830027FD6DFAF7D5CB4AF430AE062CB8989800.xkm
