I have an encfs-encrypted folder and just cut the content of a subfolder of it and pasted it into another folder outside the encfs-encrypted one. While doing that, I got an error message, saying that one subfolder couldn't be deleted because it is not empty.
The thing is, every file was pasted into the new folder and no file was left in the old one, which I checked with ls -ll -a in the subfolder:
total 8
drwxrwx--- 1 root plugdev 4096 Nov 9 16:19 .
drwxrwx--- 1 root plugdev 4096 Nov 9 16:19 ..
I don't know which information total 8 is supposed to give me here. If I try sudo ls -ll -a it says I don't have permission to do that.
Basically the same goes for rm. If I do rm -rf foldername, it says the folder is not empty. If I do sudo rm -rf foldername, it says I don't have permission to do that.
UPDATE (19th Nov):
The output of sudo smartctl --all /dev/sda is
smartctl 6.4 2014-10-07 r4002 [x86_64-linux-4.2.0-040200-generic] (local build)
Copyright (C) 2002-14, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Device Model: LITEONIT LMT-256M6M mSATA 256GB
Serial Number: TW0XXM30550853571923
Firmware Version: DM8110C
User Capacity: 256.060.514.304 bytes [256 GB]
Sector Size: 512 bytes logical/physical
Rotation Rate: Solid State Device
Device is: Not in smartctl database [for details use: -P showall]
ATA Version is: ATA8-ACS, ATA/ATAPI-7 T13/1532D revision 4a
SATA Version is: SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Thu Nov 19 10:20:30 2015 CET
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status: (0x00) Offline data collection activity
was never started.
Auto Offline Data Collection: Disabled.
Self-test execution status: ( 0) The previous self-test routine completed
without error or no self-test has ever
been run.
Total time to complete Offline
data collection: ( 10) seconds.
capabilities: (0x15) SMART execute Offline immediate.
No Auto Offline data collection support.
Abort Offline collection upon new
command.
No Offline surface scan supported.
Self-test supported.
No Conveyance Self-test supported.
No Selective Self-test supported.
SMART capabilities: (0x0002) Does not save SMART data before
entering power-saving mode.
Supports SMART auto save timer.
Error logging capability: (0x00) Error logging supported.
General Purpose Logging supported.
Short self-test routine
recommended polling time: ( 1) minutes.
Extended self-test routine
recommended polling time: ( 10) minutes.
SCT capabilities: (0x003d) SCT Status supported.
SCT Error Recovery Control supported.
SCT Feature Control supported.
SCT Data Table supported.
SMART Attributes Data Structure revision number: 1
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
5 Reallocated_Sector_Ct 0x0003 100 100 000 Pre-fail Always - 0
12 Power_Cycle_Count 0x0003 100 100 000 Pre-fail Always - 3655
175 Program_Fail_Count_Chip 0x0003 100 100 000 Pre-fail Always - 0
176 Erase_Fail_Count_Chip 0x0003 100 100 000 Pre-fail Always - 0
177 Wear_Leveling_Count 0x0003 100 100 000 Pre-fail Always - 222113
178 Used_Rsvd_Blk_Cnt_Chip 0x0003 100 100 000 Pre-fail Always - 0
179 Used_Rsvd_Blk_Cnt_Tot 0x0003 100 100 000 Pre-fail Always - 0
180 Unused_Rsvd_Blk_Cnt_Tot 0x0003 100 100 005 Pre-fail Always - 1664
181 Program_Fail_Cnt_Total 0x0003 100 100 000 Pre-fail Always - 0
182 Erase_Fail_Count_Total 0x0003 100 100 000 Pre-fail Always - 0
187 Reported_Uncorrect 0x0003 100 100 000 Pre-fail Always - 0
195 Hardware_ECC_Recovered 0x0003 100 100 000 Pre-fail Always - 0
241 Total_LBAs_Written 0x0003 100 100 000 Pre-fail Always - 286617
242 Total_LBAs_Read 0x0003 100 100 000 Pre-fail Always - 414678
SMART Error Log Version: 0
No Errors Logged
SMART Self-test log structure revision number 1
Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error
# 1 Short offline Completed without error 00% 44292 -
# 2 Short offline Completed without error 00% 56577 -
# 3 Short offline Completed without error 00% 56321 -
# 4 Short offline Completed without error 00% 56321 -
# 5 Short offline Completed without error 00% 1024 -
# 6 Short offline Completed without error 00% 1024 -
# 7 Short offline Completed without error 00% 256 -
# 8 Extended offline Completed without error 00% 0 -
Selective Self-tests/Logging not supported
