I could not find any clear answer through prior research.
Xsane fails to find the scanner with ufw enabled, works great with ufw off.
I have opened 6566 for both tcp and udp in ufw. Still no joy. I could not tell from watching the "listening report" in ufw which ports sane is using other than 6566.
If the ports are not standard but vary by scanner (this is a Canon) advice on how to locate the required ports would be most welcome.
Edit: I tried sudo ufw allow saned but I think this just opens port 6566 because the response back from the command was to the effect that it was already open.
Additional information: the port(s) that are being blocked seem to be related to scanner discovery and job status. If I disable the firewall and start xsane, then turn on the firewall and scan, a scan will take place, but it repeats over and over (apparently a job completion status is not being sent).
sudo netstat -lntp | grep saned showed port 6566 but no others. Perhaps the discovery/statuses are being sent too fast for me to see.
I would use sudo netstat -lntp | grep saned to check.
But sane has a pre-defined application profile: sudo ufw allow saned should be all you need.
(xsane is the gui for sane)
Rinzwind
  • 309,379
Since my printer has a fixed IP address on the LAN, I was able to fix this by using the command
sudo ufw allow from <ip address>
I was able to reach my HP ENVY network attached scanner with (envy is device hostname):
$ xsane $(hp-makeuri envy 2>&1 | grep SANE | cut -d: -f2-)
No nf_conntrack_sane or special firewall configuration required:
# ufw status
Status: active
To                         Action      From
443/tcp                    ALLOW       Anywhere
80/tcp                     ALLOW       Anywhere
22/tcp                     ALLOW       Anywhere
Anywhere/igmp              ALLOW       Anywhere/igmp
32400                      ALLOW       192.168.1.0/24
53                         ALLOW       192.168.1.0/24
Samba                      ALLOW       192.168.1.0/24
68/udp                     ALLOW       Anywhere
67/udp                     ALLOW       Anywhere
443/tcp (v6)               ALLOW       Anywhere (v6)
80/tcp (v6)                ALLOW       Anywhere (v6)
22/tcp (v6)                ALLOW       Anywhere (v6)
32400                      ALLOW       xxxx:xxxx:xxxx:xxxx::/64
53                         ALLOW       xxxx:xxxx:xxxx:xxxx::/64
Samba (v6)                 ALLOW       xxxx:xxxx:xxxx:xxxx::/64
68/udp (v6)                ALLOW       Anywhere (v6)
67/udp (v6)                ALLOW       Anywhere (v6)
