I have installed Ubuntu 15.10 then as root I'm using vmware 64 bit. I have already tried reinstall via the vmware installer.
When I launch vmplayer
Failed to build vmnet.  Failed to execute the build command.
Starting VMware services:
   Virtual machine monitor                                             done
   Virtual machine communication interface                             done
   VM communication interface socket family                            done
   Blocking file system                                                done
   Virtual ethernet                                                    failed
   VMware Authentication Daemon                                        done
When I build there is the followig error (see below)
tmp/modconfig-RTj6zp/vmnet-only/driver.c:1239:20: error: ‘struct file’ has no member named ‘f_dentry’
Any ideas? I tried:
$ sudo vmware-modconfig --console --install-all
Stopping VMware services:
make: Entering directory '/tmp/modconfig-RTj6zp/vmmon-only'
Using 2.6.x kernel build system.
/usr/bin/make -C /lib/modules/4.2.0-17-generic/build/include/.. SUBDIRS=$PWD SRCROOT=$PWD/. \
  MODULEBUILDDIR= modules
make[1]: Entering directory '/usr/src/linux-headers-4.2.0-17-generic'
  CC [M]  /tmp/modconfig-RTj6zp/vmmon-only/linux/driverLog.o
  CC [M]  /tmp/modconfig-RTj6zp/vmmon-only/linux/driver.o
  CC [M]  /tmp/modconfig-RTj6zp/vmmon-only/linux/hostif.o
  CC [M]  /tmp/modconfig-RTj6zp/vmmon-only/common/apic.o
  CC [M]  /tmp/modconfig-RTj6zp/vmmon-only/common/memtrack.o
  CC [M]  /tmp/modconfig-RTj6zp/vmmon-only/common/cpuid.o
  CC [M]  /tmp/modconfig-RTj6zp/vmmon-only/common/vmx86.o
  CC [M]  /tmp/modconfig-RTj6zp/vmmon-only/common/task.o
  CC [M]  /tmp/modconfig-RTj6zp/vmmon-only/common/hashFunc.o
  CC [M]  /tmp/modconfig-RTj6zp/vmmon-only/common/comport.o
  CC [M]  /tmp/modconfig-RTj6zp/vmmon-only/common/phystrack.o
  CC [M]  /tmp/modconfig-RTj6zp/vmmon-only/vmcore/moduleloop.o
/tmp/modconfig-RTj6zp/vmmon-only/linux/driver.c:1342:1: warning: always_inline function might not be inlinable [-Wattributes]
 LinuxDriverSyncReadTSCs(uint64 *delta) // OUT: TSC max - TSC min
  LD [M]  /tmp/modconfig-RTj6zp/vmmon-only/vmmon.o
  Building modules, stage 2.
  MODPOST 1 modules
  CC      /tmp/modconfig-RTj6zp/vmmon-only/vmmon.mod.o
  LD [M]  /tmp/modconfig-RTj6zp/vmmon-only/vmmon.ko
make[1]: Leaving directory '/usr/src/linux-headers-4.2.0-17-generic'
/usr/bin/make -C $PWD SRCROOT=$PWD/. \
  MODULEBUILDDIR= postbuild
make[1]: Entering directory '/tmp/modconfig-RTj6zp/vmmon-only'
make[1]: 'postbuild' is up to date.
make[1]: Leaving directory '/tmp/modconfig-RTj6zp/vmmon-only'
cp -f vmmon.ko ./../vmmon.o
make: Leaving directory '/tmp/modconfig-RTj6zp/vmmon-only'
make: Entering directory '/tmp/modconfig-RTj6zp/vmnet-only'
  CC [M]  /tmp/modconfig-RTj6zp/vmnet-only/driver.o
  CC [M]  /tmp/modconfig-RTj6zp/vmnet-only/hub.o
  CC [M]  /tmp/modconfig-RTj6zp/vmnet-only/userif.o
  CC [M]  /tmp/modconfig-RTj6zp/vmnet-only/bridge.o
  CC [M]  /tmp/modconfig-RTj6zp/vmnet-only/filter.o
  CC [M]  /tmp/modconfig-RTj6zp/vmnet-only/smac_compat.o
  CC [M]  /tmp/modconfig-RTj6zp/vmnet-only/procfs.o
  CC [M]  /tmp/modconfig-RTj6zp/vmnet-only/netif.o
In file included from /tmp/modconfig-RTj6zp/vmnet-only/monitorAction_exported.h:31:0,
                 from /tmp/modconfig-RTj6zp/vmnet-only/vnet.h:29,
                 from /tmp/modconfig-RTj6zp/vmnet-only/vnetInt.h:24,
                 from /tmp/modconfig-RTj6zp/vmnet-only/filter.c:48:
/tmp/modconfig-RTj6zp/vmnet-only/vm_assert.h:259:0: warning: "DEPRECATED" redefined
    #define DEPRECATED(_fix) do {} while (0)
In file included from include/linux/kernel.h:13:0,
                 from /tmp/modconfig-RTj6zp/vmnet-only/filter.c:20:
include/linux/printk.h:105:0: note: this is the location of the previous definition
 #define DEPRECATED "[Deprecated]: "
/tmp/modconfig-RTj6zp/vmnet-only/filter.c:207:1: error: conflicting types for ‘VNetFilterHookFn’
 VNetFilterHookFn(const struct nf_hook_ops *ops,        // IN:
/tmp/modconfig-RTj6zp/vmnet-only/filter.c:64:18: note: previous declaration of ‘VNetFilterHookFn’ was here
 static nf_hookfn VNetFilterHookFn;
                 from /tmp/modconfig-RTj6zp/vmnet-only/smac_compat.c:53:
                 from /tmp/modconfig-RTj6zp/vmnet-only/smac_compat.c:33:
/tmp/modconfig-RTj6zp/vmnet-only/filter.c:64:18: warning: ‘VNetFilterHookFn’ used but never defined
/tmp/modconfig-RTj6zp/vmnet-only/filter.c:207:1: warning: ‘VNetFilterHookFn’ defined but not used [-Wunused-function]
                 from /tmp/modconfig-RTj6zp/vmnet-only/driver.c:51:
                 from /tmp/modconfig-RTj6zp/vmnet-only/driver.c:23:
                 from /tmp/modconfig-RTj6zp/vmnet-only/procfs.c:43:
                 from /tmp/modconfig-RTj6zp/vmnet-only/procfs.c:23:
scripts/Makefile.build:258: recipe for target '/tmp/modconfig-RTj6zp/vmnet-only/filter.o' failed
make[2]: *** [/tmp/modconfig-RTj6zp/vmnet-only/filter.o] Error 1
make[2]: *** Waiting for unfinished jobs....
                 from /tmp/modconfig-RTj6zp/vmnet-only/hub.c:43:
                 from /tmp/modconfig-RTj6zp/vmnet-only/hub.c:23:
/tmp/modconfig-RTj6zp/vmnet-only/driver.c: In function ‘VNetFileOpUnlockedIoctl’:
/tmp/modconfig-RTj6zp/vmnet-only/driver.c:1239:20: <b>error: ‘struct file’ has no member named ‘f_dentry’</b>
    if (filp && filp->f_dentry) {
/tmp/modconfig-RTj6zp/vmnet-only/driver.c:1240:19: error: ‘struct file’ has no member named ‘f_dentry’
       inode = filp->f_dentry->d_inode;
                 from /tmp/modconfig-RTj6zp/vmnet-only/userif.c:45:
                 from include/linux/list.h:8,
                 from include/linux/wait.h:6,
                 from include/linux/fs.h:6,
                 from include/linux/highmem.h:4,
                 from /tmp/modconfig-RTj6zp/vmnet-only/userif.c:26:
/tmp/modconfig-RTj6zp/vmnet-only/userif.c: In function ‘VNetCopyDatagram’:
/tmp/modconfig-RTj6zp/vmnet-only/userif.c:526:11: error: implicit declaration of function ‘skb_copy_datagram_iovec’ [-Werror=implicit-function-declaration]
    return skb_copy_datagram_iovec(skb, 0, &iov, len);
                 from /tmp/modconfig-RTj6zp/vmnet-only/netif.c:42:
                 from /tmp/modconfig-RTj6zp/vmnet-only/netif.c:23:
scripts/Makefile.build:258: recipe for target '/tmp/modconfig-RTj6zp/vmnet-only/driver.o' failed
make[2]: *** [/tmp/modconfig-RTj6zp/vmnet-only/driver.o] Error 1
In file included from include/linux/pci.h:35:0,
                 from /tmp/modconfig-RTj6zp/vmnet-only/compat_netdevice.h:27,
                 from /tmp/modconfig-RTj6zp/vmnet-only/netif.c:43:
include/linux/pci_ids.h:2252:0: warning: "PCI_VENDOR_ID_VMWARE" redefined
 #define PCI_VENDOR_ID_VMWARE  0x15ad
In file included from /tmp/modconfig-RTj6zp/vmnet-only/net.h:38:0,
                 from /tmp/modconfig-RTj6zp/vmnet-only/vnetInt.h:26,
/tmp/modconfig-RTj6zp/vmnet-only/vm_device_version.h:56:0: note: this is the location of the previous definition
 #define PCI_VENDOR_ID_VMWARE                    0x15AD
/tmp/modconfig-RTj6zp/vmnet-only/netif.c: In function ‘VNetNetIf_Create’:
/tmp/modconfig-RTj6zp/vmnet-only/netif.c:152:64: error: macro "alloc_netdev" requires 4 arguments, but only 3 given
    dev = alloc_netdev(sizeof *netIf, deviceName, VNetNetIfSetup);
/tmp/modconfig-RTj6zp/vmnet-only/netif.c:152:10: error: ‘alloc_netdev’ undeclared (first use in this function)
/tmp/modconfig-RTj6zp/vmnet-only/netif.c:152:10: note: each undeclared identifier is reported only once for each function it appears in
/tmp/modconfig-RTj6zp/vmnet-only/netif.c: At top level:
/tmp/modconfig-RTj6zp/vmnet-only/netif.c:85:1: warning: ‘VNetNetIfSetup’ defined but not used [-Wunused-function]
 VNetNetIfSetup(struct net_device *dev)  // IN:
scripts/Makefile.build:258: recipe for target '/tmp/modconfig-RTj6zp/vmnet-only/netif.o' failed
make[2]: *** [/tmp/modconfig-RTj6zp/vmnet-only/netif.o] Error 1
                 from /tmp/modconfig-RTj6zp/vmnet-only/bridge.c:52:
                 from /tmp/modconfig-RTj6zp/vmnet-only/bridge.c:23:
/tmp/modconfig-RTj6zp/vmnet-only/vm_device_version.h:56:0: warning: "PCI_VENDOR_ID_VMWARE" redefined
                 from /tmp/modconfig-RTj6zp/vmnet-only/bridge.c:51:
include/linux/pci_ids.h:2252:0: note: this is the location of the previous definition
In file included from /tmp/modconfig-RTj6zp/vmnet-only/bridge.c:50:0:
/tmp/modconfig-RTj6zp/vmnet-only/bridge.c: In function ‘VNetBridgeUp’:
/tmp/modconfig-RTj6zp/vmnet-only/vmnetInt.h:81:40: error: too few arguments to function ‘sk_alloc’
 #   define compat_sk_alloc(_bri, _pri) sk_alloc(&init_net, \
/tmp/modconfig-RTj6zp/vmnet-only/bridge.c:952:17: note: in expansion of macro ‘compat_sk_alloc’
    bridge->sk = compat_sk_alloc(bridge, GFP_ATOMIC);
In file included from /tmp/modconfig-RTj6zp/vmnet-only/compat_sock.h:23:0,
                 from /tmp/modconfig-RTj6zp/vmnet-only/bridge.c:35:
include/net/sock.h:1515:14: note: declared here
 struct sock *sk_alloc(struct net *net, int family, gfp_t priority,
scripts/Makefile.build:258: recipe for target '/tmp/modconfig-RTj6zp/vmnet-only/bridge.o' failed
make[2]: *** [/tmp/modconfig-RTj6zp/vmnet-only/bridge.o] Error 1
cc1: some warnings being treated as errors
scripts/Makefile.build:258: recipe for target '/tmp/modconfig-RTj6zp/vmnet-only/userif.o' failed
make[2]: *** [/tmp/modconfig-RTj6zp/vmnet-only/userif.o] Error 1
Makefile:1398: recipe for target '_module_/tmp/modconfig-RTj6zp/vmnet-only' failed
make[1]: *** [_module_/tmp/modconfig-RTj6zp/vmnet-only] Error 2
Makefile:130: recipe for target 'vmnet.ko' failed
make: *** [vmnet.ko] Error 2
make: Leaving directory '/tmp/modconfig-RTj6zp/vmnet-only'
Unable to install all modules.  See log for details.
Oli
  • 299,380
This appears to be, to me, a case where VMware hasn't updated their software yet for the latest kernel, so it's entirely possible it can't build under this version. It also appears it's relying on functions that aren't 'common' anymore.
There may be patches online, however you are going to faces some headaches and such going forward. I would reach out to VMware to see if they have a solution currently, as there's not much we can really do right now...
Thomas Ward
  • 78,878
VMPlayer 7 has a known issue with patches, as referred to in this answer, and VMPlayer 12, the current version, has a bug referred to in this answer.
I would suggest that you download the current VMPlayer from vmware.com, and modify the wrapper file so that vmplayer will execute:
Open a terminal window ctrl+alt+t, and enter the following command
sudo nano /usr/bin/vmplayer
scroll down a few lines to a line which says set -e
Input a new line:
export LD_LIBRARY_PATH=/usr/lib/vmware/lib/libglibmm-2.4.so.1/:$LD_LIBRARY_PATH
Press ctrl+o and ctrl+x to save and exit, and you should be good to go.
Charles Green
  • 21,859
