I'm trying to install mysql-server package, but I have this error message:
/home/nikitasorokin# apt-get install mysql-server
Reading package lists... Done
Building dependency tree
mysql-server is already the newest version.
The following packages were automatically installed and are no longer required:
  libaio1 ndn-mysql5-helper
Use 'apt-get autoremove' to remove them.
0 upgraded, 0 newly installed, 0 to remove and 5 not upgraded.
2 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Do you want to continue? [Y/n] y
Setting up mysql-server-5.5 (5.5.46-0ubuntu0.12.04.2) ...151108 11:54:25 [Warning] Using unique option prefix key_buffer instead of key_buffer_size is deprecated and will be removed in a future release. Please use the full name instead.
151108 11:54:25 [Note] /usr/sbin/mysqld (mysqld 5.5.46-0ubuntu0.12.04.2) starting as process 14876 ...
start: Job failed to start
invoke-rc.d: initscript mysql, action "start" failed.
dpkg: error processing package mysql-server-5.5 (--configure):
 subprocess installed post-installation script returned error exit status 1
dpkg: dependency problems prevent configuration of mysql-server:
 mysql-server depends on mysql-server-5.5; however:
  Package mysql-server-5.5 is not configured yet.
dpkg: error processing package mysql-server (--configure):
 dependency problems - leaving unconfigured
 mysql-server-5.5
 mysql-server
Apt-cache
/home/nikitasorokin# apt-cache policy mysql-server-5.5
mysql-server-5.5:
  Installed: 5.5.46-0ubuntu0.12.04.2
  Candidate: 5.5.46-0ubuntu0.12.04.2
  Version table:
 *** 5.5.46-0ubuntu0.12.04.2 0
        500 http://mirror.newdream.net/ubuntu/ precise-updates/main amd64 Packages
        500 http://mirror.newdream.net/ubuntu/ precise-security/main amd64 Packages
        100 /var/lib/dpkg/status
 5.5.22-0ubuntu1 0
        500 http://mirror.newdream.net/ubuntu/ precise/main amd64 Packages
Thanks in advance!
