You have 2 problems here:
- Auto-login to a command line session
- Keeping the output of the script after its execution
I think the first problem can be solved like explained here: How to autologin (without entering username and password)(in text mode)
You have multiple options for the second problem.
Option 1: storing the output of the script in a text file, and displaying it at login
In order to do that, you need to redirect the output of the script to a file. You can do that by adding > /path/to/file when you invoke the script.
./yourscript.sh > /tmp/myOutput
Then, you add the following line into your ~/.bashrc file (create it if it does not exist), asking bash to read that file when you login:
cat /tmp/myOutput
The output of the last execution of the startup script should now be displayed each time you log into the system.
Option 2: using tmux (terminal multiplexer)
You can run the execution of the script inside a tmux session, and then, at login time, attach to that session. That way, you'll have the history of the execution.
Tmux is easily installable on Ubuntu with apt-get install tmux
