I am using Ubuntu 14.04 LTS on my other desktop PC which doesn't have internet connection.
I wanted to install XFCE desktop environment on it so I have downloaded the file xfce-4.6.1-src.tar.bz2, but I don't know how I can install it.
Please, can somebody guide me step by step? Thank You
Byte Commander
  • 110,243
First you want this file, use another PC to get it.
OK This is going to take you a long time, you must compile each part individually
First put the file in your /home folder and extract the package
tar xvjf xfce-4.12.tar.bz2
That will extract to a folder called src, change to this folder
cd src
In here are lots of tar.bz2 files, you must compile each one in the following order
xfce4-dev-tools (only required if you build from GIT)
libxfce4util
xfconf
libxfce4ui, garcon
exo
xfce4-panel
thunar
xfce4-settings, xfce4-session, xfdesktop, xfwm4, xfce4-appfinder
Now this is an issue for you, you need these xfce dependancies,
autoconf automake intltool pkgconfig glib2.0 gtk+-2.0 dbus-glib2.0 xfconf gio2.0 libglade2.0 perl libwnck* gudev-1.0
If they are not installed the build will just fail, if it fails you can google .debs for all of these and download them on another PC.
Now we will build the first package, extract it
tar xvjf xfce4-dev-tools.tar.bz2
Enter its directory
cd xfce4-dev-tools
Now configure
./configure
Now make
make
Now install it
make install
Now go back to the src directory
cd ~/src
Extract, configure and make the next one
tar xvjf libxfce4util.tar.bz2
cd libxfce4util
./configure
make
make install
cd ~/src
You get the point, once all packages are successfully made and installed in the correct order, you can log out and select xfce from log in screen.
SOURCE
Mark Kirby
  • 18,949
  • 19
  • 79
  • 116
