I recently ran:
sudo apt-get update && sudo apt-get dist-upgrade
And that installed the latest version of the linux kernel for 15.10. However, once I ran:
sudo apt-get autoremove
I got this output:
Reading package lists... Done
Building dependency tree
The following packages will be REMOVED
linux-headers-4.2.0-16 linux-headers-4.2.0-16-generic
linux-image-4.2.0-16-generic linux-image-extra-4.2.0-16-generic
0 to upgrade, 0 to newly install, 4 to remove and 0 not to upgrade.
After this operation, 287 MB disk space will be freed.
Do you want to continue? [Y/n] y
(Reading database ... 266582 files and directories currently installed.)
Removing linux-headers-4.2.0-16-generic (4.2.0-16.19) ...
Removing linux-headers-4.2.0-16 (4.2.0-16.19) ...
Removing linux-image-extra-4.2.0-16-generic (4.2.0-16.19) ...
run-parts: executing /etc/kernel/postinst.d/apt-auto-removal 4.2.0-16-generic /boot/vmlinuz-4.2.0-16-generic
run-parts: executing /etc/kernel/postinst.d/dkms 4.2.0-16-generic /boot/vmlinuz-4.2.0-16-generic
dkms: WARNING: Linux headers are missing, which may explain the above failures.
please install the linux-headers-4.2.0-16-generic package to fix this.
run-parts: executing /etc/kernel/postinst.d/initramfs-tools 4.2.0-16-generic /boot/vmlinuz-4.2.0-16-generic
update-initramfs: Generating /boot/initrd.img-4.2.0-16-generic
run-parts: executing /etc/kernel/postinst.d/unattended-upgrades 4.2.0-16-generic /boot/vmlinuz-4.2.0-16-generic
run-parts: executing /etc/kernel/postinst.d/update-notifier 4.2.0-16-generic /boot/vmlinuz-4.2.0-16-generic
run-parts: executing /etc/kernel/postinst.d/zz-update-grub 4.2.0-16-generic /boot/vmlinuz-4.2.0-16-generic
Generating grub configuration file ...
Warning: Setting GRUB_TIMEOUT to a non-zero value when GRUB_HIDDEN_TIMEOUT is set is no longer supported.
Found linux image: /boot/vmlinuz-4.2.0-17-generic
Found initrd image: /boot/initrd.img-4.2.0-17-generic
Found linux image: /boot/vmlinuz-4.2.0-16-generic
Found initrd image: /boot/initrd.img-4.2.0-16-generic
Found memtest86+ image: /memtest86+.elf
Found memtest86+ image: /memtest86+.bin
done
Removing linux-image-4.2.0-16-generic (4.2.0-16.19) ...
Examining /etc/kernel/prerm.d.
run-parts: executing /etc/kernel/prerm.d/dkms 4.2.0-16-generic /boot/vmlinuz-4.2.0-16-generic
Examining /etc/kernel/postrm.d .
run-parts: executing /etc/kernel/postrm.d/initramfs-tools 4.2.0-16-generic /boot/vmlinuz-4.2.0-16-generic
update-initramfs: Deleting /boot/initrd.img-4.2.0-16-generic
run-parts: executing /etc/kernel/postrm.d/zz-update-grub 4.2.0-16-generic /boot/vmlinuz-4.2.0-16-generic
done
The link /vmlinuz.old is a damaged link
Removing symbolic link vmlinuz.old
you may need to re-run your boot loader[grub]
The link /initrd.img.old is a damaged link
Removing symbolic link initrd.img.old
In which this error stood out the most (I think I may have got the error during the installation as well but I can't really remember):
I have had a look at this question already but it was of no help. So what exactly does this error mean and what should I do about it?
OS Information:
LSB Version: core-2.0-amd64:core-2.0-noarch:core-3.0-amd64:core-3.0-noarch:core-3.1-amd64:core-3.1-noarch:core-3.2-amd64:core-3.2-noarch:core-4.0-amd64:core-4.0-noarch:core-4.1-amd64:core-4.1-noarch
Distributor ID: Ubuntu
Description: Ubuntu 15.10
Release: 15.10
Codename: wily
Flavour: GNOME
GNOME Version: 3.18
