I am trying to install bitcoin server using this guide
https://www.sky-ip.org/configure-bitcoin-node-debian-ubuntu.html
However when I make, I see the error
g++: internal compiler error: Killed (program cc1plus)
Please submit a full bug report,
with preprocessed source if appropriate.
Making all in src
make[1]: Entering directory /root/bitcoinsrc/bitcoin/src
make[2]: Entering directory /root/bitcoinsrc/bitcoin/src
CXX      libbitcoin_server_a-main.o
See file:///usr/share/doc/gcc-4.9/README.Bugs for instructions.
make[2]: ** [libbitcoin_server_a-main.o] Error 4
make[2]: Leaving directory /root/bitcoinsrc/bitcoin/src
make[1]: ** [all-recursive] Error 1
make[1]: Leaving directory /root/bitcoinsrc/bitcoin/src
make: ** [all-recursive] Error 1'
Following advice to install and use clang instead, I can't get Ubuntu to actually use Clang:
When I try to make It still uses the old GCC. When i try 'sudo apt-get update-alternatives --config c++'
E: Command line option --config is not understood
When I try sudo update-alternatives --query c++ I get
Link: /usr/bin/c++
Slaves:
c++.1.gz /usr/share/man/man1/c++.1.gz
Status: auto
Best: /usr/bin/clang++-3.6
Value: /usr/bin/clang++-3.6
Alternative: /usr/bin/clang++-3.6
Priority: 100
Slaves:
Alternative: /usr/bin/g++
Priority: 20
Slaves:
c++.1.gz /usr/share/man/man1/g++.1.gz
I want to be able to compile this somehow someway. This is my first time trying to compile so I am pretty unfamiliar with it. Please explain noobly
Derek
