11
I have set few aliases in .bashrc file. I need those aliases most of the time, but sometimes I need to run those command without options set in that particular alias.
How to not execute alias command?
Alex Jones
  • 8,192
Run the command with a leading \, an answer in examples: ;)
% ls
bar  foo
% alias ls="ls -laog"
% ls
total 4292
drwxrwxr-x  4 4329472 Nov  5 15:06 .
drwx------ 95   28672 Nov  5 15:15 ..
-rw-rw-r--  1       0 Nov  5 15:06 bar
drwxrwxr-x  2    4096 Nov  5 15:06 foo
drwxrwxr-x  2    4096 Okt  2 14:29 .foo
-rw-rw-r--  1     191 Feb 25  2015 .htaccess
% \ls
bar  foo
Slightly longer but also possible:
command ls
A.B.
  • 92,125
10
You can use shell builtin command to escape aliases (and functions):
command alias_name
For example:
command ls
will run /bin/ls binary , not any alias defined as ls.
An alternative is to use quotes:
"alias_name"
or
'alias_name'
For example:
"ls"
or
'ls'
these again will run the /bin/ls binary, ignoring any alias ls.
heemayl
  • 93,925
Alternatively, you could specify full path to command. For instance, my ls command is aliased to ls='ls --color -F'
What one can do is either call /bin/ls or $(which ls) (for those of us who are lazy to type full path).
Example : calling original command with flags $(which ls) -l
