Hello I need to find out how to enable a system wide proxy in xubuntu 10.10
txwikinger
  • 29,406
Whilst the the other answers are good & ok (for terminal/bash prompts), in my opinion the correct place to add these are /etc/environment.
Use sudo or gksu then add:
http_proxy="http://user:password@proxyserver:port"
https_proxy="http://user:password@proxyserver:port"
ftp_proxy="http://user:password@proxyserver:port"
Very similar but for those who run everything from within a term then yes the other answers will give results but for those in GUI land would be better off adding the above line to the environment file for full correct system wide usage.
fossfreedom
  • 174,526
t0m5k1
  • 81
Add to following lines to your ~/.bashrc file:
export http_proxy="http://user:password@proxyserver:port"
export https_proxy="http://user:password@proxyserver:port"
export ftp_proxy="http://user:password@proxyserver:port"
8128
  • 28,868
borjacampina
  • 1,054
there is a graphical tool called UbProxy, that sets the whole systema proxy, via a graphical interface (GUI). The only problem for me, was I have to log out my user and log in again to load the config. Is very simple to use. https://code.google.com/p/ubproxy/
Sergio
  • 121
