I have Desktop with ubuntu Linux installed. I don't have Internet Connection at home. I download Linux base application on USB Drive. How I can install those application in Ubuntu. Help or guide me to install softwarae
Asked
Active
Viewed 1,414 times
If you want to install deb packages without a Internet connection.
you can use dpkg -i <package name>
example:
Download the package that you want.
copy the package to your /home/<user> folder.
Run this command. I am only using PlayOnLinux_4.2.9.deb as an example your package name may be different.
sudo dpkg -i PlayOnLinux_4.2.9.deb
You must know PlayOnLinux and other packages have dependencies and you wont be able to install offline unless you have all the dependencies for the package downloaded or installed.
These are the dependencies for PlayonLinux are.
unzip, wget, xterm | x-terminal-emulator, python, python-wxgtk2.8 | python-wxgtk3.0, imagemagick, cabextract, icoutils, p7zip-full, curl
How to find a package Depends run this command. package.deb being your package name
dpkg -I package.deb
Mark Kirby
- 18,949
- 19
- 79
- 116
Neil
- 4,585
