I am trying to install eclipse + elim in a remote linux server where there is no internet connection and no display available (I am accessing the server using putty). Also I don't have root access in this server. eclim is installed successfully in the server but when I am trying to run eclimd it is throwing error like below:
Exception in thread "Thread-4" java.lang.NoClassDefFoundError: org/eclipse/ui/PlatformUI
        at org.eclim.eclipse.EclimApplication.shutdown(EclimApplication.java:144)
        at org.eclim.eclipse.EclimApplication$1.run(EclimApplication.java:102)
Caused by: java.lang.ClassNotFoundException: org.eclipse.ui.PlatformUI cannot be found by org.eclim_2.5.0
        at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:439)
        at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:352)
        at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:344)
        at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:160)
        at java.lang.ClassLoader.loadClass(ClassLoader.java:357)
        ... 2 more
How can I run eclimd in this server?
As you say you do not have root access, the following steps install everything to your home folder:
Download and install eclipse
  1. Download eclipse here, eg. Eclipse IDE for Java EE Developers 64-bit.
  2. Extract the archive, change the name of the archive if necessary
     tar xf eclipse-jee-mars-1-linux-gtk-x86_64.tar.gz -C ~
Install and run eclim
  1. Install eclim with -Declipse.home="$HOME/eclipse"
    Check the filename eclim_2.5.0.jar and replace it if necessary
     java -Dvim.files=$HOME/.vim -Declipse.home="$HOME/eclipse" -jar eclim_2.5.0.jar install
  2. Run eclimd
     ./eclipse/eclimd -b
Partially taken from here
A.B.
  • 92,125
