i want to install libcairo2 (>= 1.12.0) on my 12.04 LTS. I need this package for monodevelop package. Any idea?
 rafael@rafael-note:~/Downloads/cairo-1.12.0$ sudo apt-get install
 monodevelop Reading package lists...Done
 Building dependency tree
 Some packages could not be installed. This may mean that you have requested an impossible
 situation or if you are using the unstable distribution that some
 required packages have not yet been created or been moved out of
 Incoming. The following information may help to resolve the situation:
 The following packages have unmet dependencies:  monodevelop :
 Depends: libcairo2 (>= 1.12.0) but 1.10.2-6.1ubuntu3 is to be
 installed E: Unable to correct problems, you have held broken
 packages.
pl_rock
  • 11,715
monodevelop packages depend on libcairo2 version 1.12.0 or grater but Ubuntu 12.04 have 1.10.2-6 version (you can see here) so you have to manually download and install from here or here.
  wget http://archive.ubuntu.com/ubuntu/pool/main/c/cairo/libcairo2_1.14.2-1ubuntu1_amd64.deb
  sudo dpkg -i libcairo2_1.14.2-1ubuntu1_amd64.deb
download version according to your system configuration (64bit or 32bit ) if it still show any dependency then try command:
sudo apt-get install -f
pl_rock
  • 11,715
