Possible Duplicate:
Are the Ralink RT3090 drivers incompatible with Ubuntu 10.10?
I have an issue with my wireless network,so that the connection is working for only a few minutes, after which my browser no longer is able to load pages, even if the wireless is still active/connected.
Furthermore, most of the time WPA2-personal protected networks don't work, (yesterday was the first time it worked - for a few minutes). By "don't work" I mean that it seems to successfully connect, but the browser can't load pages.
I am running Ubuntu 10.10 32bit, and my wireless card is a RaLink rt3090. No changes have been done to any settings since Ubuntu was installed - networking began working on its own after the installation - but as described in first paragraph not very well.
Pedro
  • 171
Have you tried to eliminate possible external factors? Check signal strength; sources of interference; alternative channel number.
outofstep
  • 271
this solution worked for me on ubuntu 10.10 on hp 4520s probook:
Go to your terminal and type in this command: lsmod | grep rt
Your output will lokk something similar to this one:
rt2860sta 488820 0 rt2800usb 37372 0 [...]
This gives the hint to the solution:
Steps to the solution:
open your Terminal and first type in this: sudo modprobe rf rt2800pci
Then afterwards type in this: sudo modprobe -rf rt2860sta
As the next step follows this command in your terminal: sudo modprobe rt2860sta
Just as you type in this, your networkmanager connects automaticly and comes back to work!!!
But to close the whole thing up, you need tot ype in this command, for finishing up:
echo blacklist rt2800pci | sudo tee -a /etc/modprobe.d/blacklist.conf
Jorge Castro
  • 73,717
I had the same issue in several computers running 10.10 with different wifi adapters. In the end, the conclusion is that network-manager-gnome has a bug causing the connection freeze. My solution was to use the package manager to remove "network-manager-gnome" and install "wicd". WICD is a network manager that doesn't have this annoying bug that canonical was not able to fix since 10.04.
We've already talked about this. Can you merge threads (questions) in stack exchange?
xd1936
  • 345
