I have installed amd drivers from the update manager and after that Ubuntu is stacked onthe start splash, somebody can help? The driver is flgxr updates and the graphic car is an r9 270x.
AFS
  • 205
So, I believe that you need to remove the AMD drivers. If you can do this from a terminal after booting, great! If not, then you will need to boot into a recovery mode and try to remove them there.
To get to recovery mode, hold your left shift key while Ubuntu boots. At the grub menu, choose "Advanced Options for Ubuntu, then the line which says "...(recovery mode)"
In recovery mode, choose the 'networking' mode so that you can do a little re-installation work as well. From here, the instructions are the same in both recovery mode and in a terminal window.
Try to completely remove your ATI/AMD drivers from your system: Please note that these instructions are lifted verbatim from this answer
sudo apt-get purge "fglrx.*"
Remove your xorg.conf
sudo rm /etc/X11/xorg.conf
Reinstall xorg completely
sudo apt-get install --reinstall xserver-xorg-core libgl1-mesa-glx:i386 libgl1-mesa-dri:i386 libgl1-mesa-glx:amd64 libgl1-mesa-dri:amd64
Re-configure Xorg
sudo dpkg-reconfigure xserver-xorg
Reboot
sudo reboot
You should be greeted with lightdm, this will default everything x the same way a fresh install would.
Charles Green
  • 21,859
