I connect to my server via ssh that has erlang and cowboy installed on it for running my webpage.
ssh root@my.ip.adress
I then start up my webapp by doing;
./_rel/web_server_example/bin/web_server_example console
Which leaves me at a final line containing;
(web_server_example@127.0.0.1)1>
the erlang prompt. Now I need both the server and my home computer that is connected to it, because if I close the terminal it stops the erlang program on the server. How can I keep the program running and have my home computer off?
RiaanV
  • 223
You have (at least) 2 options:
1) Use nohup. Command:
nohup ./_rel/web_server_example/bin/web_server_example console &
then you can exit your ssh session. The output of your process will be redirected to file nohup.out
2) Use GNU screen. You will likely need to install it first: apt-get install screen. Then:
screen bash
<Ctrl-A> D
At this stage you will have a screen session running in the background. You can exit your ssh session. The beauty of the screen way of doing things is that you can re-attach later. Log on to that server and type in command screen -r. You will back to your web_server_example command and you can do things like pressing to interrupt it or interract with it in some other way.
sмurf
  • 4,750
  • 26
  • 30
