After upgrade to 15.10, my laptop no longer suspends. dmesg says
[…] PM: Syncing filesystems ... done.
[…] PM: Preparing system for sleep (mem)
[…] Freezing user space processes ... (elapsed 0.001 seconds) done.
[…] Freezing remaining freezable tasks ...
[…] Freezing of tasks failed after 20.008 seconds (0 tasks refusing to freeze, wq_busy=1):
That seems to blame wq_busy for being true, but I'm not having luck finding out why that might be the case or how I might fix it. (Internet searches seems to always pull up the more popular case where a task refuses to freeze.) What does wq_busy=1 indicate?
Edward
  • 251
wq_busy is apparently the kernel's variable name for the busy flag on a workqueue. Why it was stuck at true for some workqueue on my machine is unclear, because the problem went away while I was trying to diagnose it. In case it's useful for someone in the future, I had done the following:
  1. Repeatedly until all applications were closed:
    1. Close an application.
    2. Attempt, unsuccessfully, to suspend.
  2. Disable networking.
  3. Attempt, unsuccessfully, to suspend.
  4. Reboot (intending to get a clean process list; I was going to progressively disable things in hopes that a non-critical process was the culprit).
  5. Attempt, unexpectedly successfully, to suspend.
  6. Re-enable networking.
  7. Attempt, again successfully, to suspend.
So, strictly based on observations, and not with any understanding of the problem, I would guess that the following is a workaround or fix:
  1. Disable networking.
  2. Reboot.
  3. Re-enable networking.
Edward
  • 251
I had the same issue. wq_busy was 1. I suspected that it had started to happen after 18.10 upgrade.
I did some research and found a post about looking for hardware-specific solutions especially for laptops, and another post about cdemu.
https://forums.gentoo.org/viewtopic-t-952364-start-0.html
In my case, removing gcdemu, cdemu-client, cdemu-daemon, and then autoremove vhba-dkms and libmirage11 made my hibernation working again.
qba-dev
  • 424
I enabled hibernation some month ago in my Ubuntu system, now 20.04, but now as in the past I had some issue. So in this last event I found this in "dmsg" during hibernation procedure:
 Freezing of tasks failed after 20.005 seconds (0 tasks refusing to freeze, wq_busy=1)...
I solved with increasing the freezing timeout from 20 sec to 30 sec:
echo 30000 > /sys/power/pm_freeze_timeout
and made I it permanent with sysfsutils and after writing
power/pm_freeze_timeout = 30000
in a file in the /etc/sysfs.d directory
Wedra
