I have an Ubuntu 15.04 and installed Unity, Gnome3 and Awesome WM.
All worked fine: I could start any Desktop Environment by any Display Manager
Recently I installed a SLiM DM.
$ sudo apt-get install slim
I still can start all DE by LightDM and GDM, but by the SLiM DM i can run only the Awesome WM.
When i try to start Gnome or Unity by SLiM via choosing X-session (pressing F1) and typing login and password, there is an error:
Xsession: unsupported number of arguments (2); falling back to default session
And i see a symbol X instead of arrow, and when i type OK, there is only my desktop background without any windows and arrow.
This is the content of my ~/.xinitrc file:
#!/bin/sh
. /etc/X11/Xsession
/etc/slim.conf
# Path, X server and arguments (if needed)
# Note: -xauth $authfile is automatically appended
default_path        /usr/local/bin:/usr/bin:/bin:/usr/local/games:/usr/games
default_xserver     /usr/bin/X11/X
xserver_arguments   -nolisten tcp
# Commands for halt, login, etc.
halt_cmd            /sbin/shutdown -h now
reboot_cmd          /sbin/shutdown -r now
console_cmd         /usr/bin/xterm -C -fg white -bg black +sb -T "Console login" -e /bin/sh -c "/bin/cat /etc/issue.net; exec /bin/login"
#suspend_cmd        /usr/sbin/suspend
# Full path to the xauth binary
xauth_path         /usr/bin/X11/xauth
# Xauth file for server
authfile           /var/run/slim.auth
# Activate numlock when slim starts. Valid values: on|off
# numlock             on
# Hide the mouse cursor (note: does not work with some WMs).
# Valid values: true|false
# hidecursor          false
# This command is executed after a succesful login.
# you can place the %session and %theme variables
# to handle launching of specific commands in .xinitrc
# depending of chosen session and slim theme
# NOTE: if your system does not have bash you need
# to adjust the command according to your preferred shell,
# i.e. for freebsd use:
login_cmd           exec /bin/sh - ~/.xinitrc %session
# login_cmd           exec /bin/bash -login /etc/X11/Xsession %session
# Commands executed when starting and exiting a session.
# They can be used for registering a X11 session with
# sessreg. You can use the %user variable
# sessionstart_cmd      some command
# sessionstop_cmd       some command
# Start in daemon mode. Valid values: yes | no
# Note that this can be overriden by the command line
# options "-d" and "-nodaemon"
# daemon        yes
# Set directory that contains the xsessions.
# slim reads xsesion from this directory, and be able to select.
sessiondir            /usr/share/xsessions/
# Executed when pressing F11 (requires scrot)
screenshot_cmd      scrot /root/slim.png
# welcome message. Available variables: %host, %domain
welcome_msg         Welcome to %host
# Session message. Prepended to the session name when pressing F1
# session_msg         Session:
# shutdown / reboot messages
shutdown_msg       The system is halting...
reboot_msg         The system is rebooting...
# default user, leave blank or remove this line
# for avoid pre-loading the username.
#default_user        simone
# Focus the password field on start when default_user is set
# Set to "yes" to enable this feature
#focus_password      no
# Automatically login the default user (without entering
# the password. Set to "yes" to enable this feature
#auto_login          no
# current theme, use comma separated list to specify a set to
# randomly choose from
current_theme       debian-lines
# Lock file
lockfile            /var/run/slim.lock
# Log file
logfile             /var/log/slim.log
/etc/X11/Xsession
#!/bin/sh
# /etc/X11/Xsession
# global Xsession file -- used by display managers and xinit (startx)
# $Id: Xsession 967 2005-12-27 07:20:55Z dnusinow $
set -e
#set meta-flag on
#set convert-meta off
#set output-meta on
PROGNAME=Xsession
message () {
  # pretty-print messages of arbitrary length; use xmessage if it
  # is available and $DISPLAY is set
  MESSAGE="$PROGNAME: $*"
  echo "$MESSAGE" | fold -s -w ${COLUMNS:-80} >&2
  if [ -n "$DISPLAY" ] && which xmessage > /dev/null 2>&1; then
    echo "$MESSAGE" | fold -s -w ${COLUMNS:-80} | xmessage -center -file -
  fi
message_nonl () {
  # pretty-print messages of arbitrary length (no trailing newline); use
  # xmessage if it is available and $DISPLAY is set
  echo -n "$MESSAGE" | fold -s -w ${COLUMNS:-80} >&2;
    echo -n "$MESSAGE" | fold -s -w ${COLUMNS:-80} | xmessage -center -file -
  fi
errormsg () {
  # exit script with error
  message "$*"
  exit 1
internal_errormsg () {
  # exit script with error; essentially a "THIS SHOULD NEVER HAPPEN" message
  # One big call to message() for the sake of xmessage; if we had two then
  # the user would have dismissed the error we want reported before seeing the
  # request to report it.
  errormsg "$*" \
           "Please report the installed version of the \"x11-common\"" \
           "package and the complete text of this error message to" \
           "<debian-x@lists.debian.org>."
# initialize variables for use by all session scripts
OPTIONFILE=/etc/X11/Xsession.options
SYSRESOURCES=/etc/X11/Xresources
USRRESOURCES=$HOME/.Xresources
SYSSESSIONDIR=/etc/X11/Xsession.d
USERXSESSION=$HOME/.xsession
USERXSESSIONRC=$HOME/.xsessionrc
ALTUSERXSESSION=$HOME/.Xsession
ERRFILE=$HOME/.xsession-errors
# attempt to create an error file; abort if we cannot
if (umask 077 && touch "$ERRFILE") 2> /dev/null && [ -w "$ERRFILE" ] &&
  [ ! -L "$ERRFILE" ]; then
  chmod 600 "$ERRFILE"
elif ERRFILE=$(tempfile 2> /dev/null); then
  if ! ln -sf "$ERRFILE" "${TMPDIR:=/tmp}/xsession-$USER"; then
    message "warning: unable to symlink \"$TMPDIR/xsession-$USER\" to" \
             "\"$ERRFILE\"; look for session log/errors in" \
             "\"$TMPDIR/xsession-$USER\"."
  fi
else
  errormsg "unable to create X session log/error file; aborting."
fi
# truncate ERRFILE if it is too big to avoid disk usage DoS
if [ "`stat -c%s \"$ERRFILE\"`" -gt 500000 ]; then
  T=`mktemp -p "$HOME"`
  tail -c 500000 "$ERRFILE" > "$T" && mv -f "$T" "$ERRFILE" || rm -f "$T"
fi
exec >>"$ERRFILE" 2>&1
echo "$PROGNAME: X session started for $LOGNAME at $(date)"
# sanity check; is our session script directory present?
if [ ! -d "$SYSSESSIONDIR" ]; then
  errormsg "no \"$SYSSESSIONDIR\" directory found; aborting."
fi
# Attempt to create a file of non-zero length in /tmp; a full filesystem can
# cause mysterious X session failures.  We do not use touch, :, or test -w
# because they won't actually create a file with contents.  We also let standard
# error from tempfile and echo go to the error file to aid the user in
# determining what went wrong.
WRITE_TEST=$(tempfile)
if ! echo "*" >>"$WRITE_TEST"; then
  message "warning: unable to write to ${WRITE_TEST%/*}; X session may exit" \
          "with an error"
fi
rm -f "$WRITE_TEST"
# use run-parts to source every file in the session directory; we source
# instead of executing so that the variables and functions defined above
# are available to the scripts, and so that they can pass variables to each
# other
SESSIONFILES=$(run-parts --list $SYSSESSIONDIR)
if [ -n "$SESSIONFILES" ]; then
  set +e
  for SESSIONFILE in $SESSIONFILES; do
    . $SESSIONFILE
  done
  set -e
fi
exit 0
# vim:set ai et sts=2 sw=2 tw=80:
Why the GDM and the LightDM can start my Gnome and Unity properly, and SLiM can't?
Reputet
  • 31
