After installing Kubuntu 15.10 non-English (i.e. Greek) file names are not shown in file search. Any ideas about this issue?
(A QT issue caused some trouble in Firefox under 15.04, if I recall this right)
I don't use international character sets much but I do have some files with non-English character names from other testing, and I can find them in Dolphin 17.12.2 on KDE Frameworks 5.47.0.
balooshow -x /path/to/file will show what KDE's Baloo file indexer thinks is going on. I tried it with some Greek characters in the file name:
 % echo 'Another test of Baloo/Dolphin file name indexing' > γένεος_baloo_test.txt
 % balooshow -x γένεος_baloo_test.txt
621851134983427 64771 144786 /home/spage/γένεος_baloo_test.txt
        Line Count: 1
Internal Info
Terms: Mplain Mtext T5 T8 Ttext X20-1 another baloo dolphin file indexing name of test
File Name Terms: Fbaloo Ftest Ftxt Fγενεος baloo test txt γενεος
and I can find that file by Filename in Dolphin by entering two or more letters from the start of any of the file name terms, including γέ.
I couldn't find Kanji characters:
% balooshow -x 日本国_déjà_balootest.txt
566660805229827 64771 131936 /home/spage/日本国_déjà_balootest.txt
        Line Count: 1
Internal Info
Terms: Mplain Mtext T5 T8 Ttext X20-1 another file test
File Name Terms: Fbalootest Fdeja Ftxt balootest deja txt
Note how the Kanji characters didn't appear in "File Name Terms." I think this is why find by Filename for "deja" or "déjà" finds this file, but searching for the Kanji characters is a bust.
skierpage
  • 313
I had the same issue in Arch Linux but it might help you. This is an issue of correctly setting the locale.
First thing, you need to generate your locales. For this you must uncomment the corresponding lines for each needed locale in /etc/locale.gen. For example, for Greek and American English locales uncomment the lines:
el_GR.UTF-8 UTF-8
el_GR ISO-8859-7
en_US.UTF-8 UTF-8
en_US ISO-8859-1
you now need to generate the locale:
# locale-gen
set your language in /etc/locale.conf (for example for US English)
LANG="en_US.UTF-8"
and logout/reboot
