Say I have a range of files named: "blah-10-blah", "blah-11-blah" etc...up to "blah-30-blah".
I would like to change the names to "blah-20-blah", "blah-21-blah" etc...up to "blah-40-blah".
Is there a way of doing this in the terminal?
kos
  • 41,268
Orm
It's important to process the files in an inverse numerical order, otherwise the task will fail due to already existing files with the target filename:
find . -maxdepth 1 -type f -name 'blah-??-blah' -print0 | sort -zr | xargs -0 rename 's/-\K([0-9]{2})/$1+10/e'
  • find . -maxdepth 1 -type f -name 'blah-??-blah' -print0: prints a NULL-separated list of the files in the current working directory matching the globbing pattern blah-??-blah;
  • sort -zr: sorts the list in an inverse numerical order;
  • xargs -0 rename 's/-\K([0-9]{2})/$1+10/e': renames the files substituting the first couple of digits after a dash with the correspondent value incremented by 10;
% tree
├── blah-10-blah
├── blah-11-blah
├── blah-12-blah
├── blah-13-blah
├── blah-14-blah
├── blah-15-blah
├── blah-16-blah
├── blah-17-blah
├── blah-18-blah
├── blah-19-blah
├── blah-20-blah
├── blah-21-blah
├── blah-22-blah
├── blah-23-blah
├── blah-24-blah
├── blah-25-blah
├── blah-26-blah
├── blah-27-blah
├── blah-28-blah
├── blah-29-blah
└── blah-30-blah
0 directories, 21 files
% find . -maxdepth 1 -type f -name 'blah-??-blah' -print0 | sort -zr | xargs -0 rename 's/-\K([0-9]{2})/$1+10/e'
% tree
├── blah-20-blah
├── blah-21-blah
├── blah-22-blah
├── blah-23-blah
├── blah-24-blah
├── blah-25-blah
├── blah-26-blah
├── blah-27-blah
├── blah-28-blah
├── blah-29-blah
├── blah-30-blah
├── blah-31-blah
├── blah-32-blah
├── blah-33-blah
├── blah-34-blah
├── blah-35-blah
├── blah-36-blah
├── blah-37-blah
├── blah-38-blah
├── blah-39-blah
└── blah-40-blah
If using Zsh, the task can be heavily simplified, as Zsh allows to expand filenames in an inverse numerical order:
rename 's/-\K([0-9]{2})/$1+10/e' blah-??-blah(On)
% tree
├── blah-10-blah
├── blah-11-blah
├── blah-12-blah
├── blah-13-blah
├── blah-14-blah
├── blah-15-blah
├── blah-16-blah
├── blah-17-blah
├── blah-18-blah
├── blah-19-blah
├── blah-20-blah
├── blah-21-blah
├── blah-22-blah
├── blah-23-blah
├── blah-24-blah
├── blah-25-blah
├── blah-26-blah
├── blah-27-blah
├── blah-28-blah
├── blah-29-blah
└── blah-30-blah
% rename 's/-\K([0-9]{2})/$1+10/e' blah-??-blah(On)
% tree
├── blah-20-blah
├── blah-21-blah
├── blah-22-blah
├── blah-23-blah
├── blah-24-blah
├── blah-25-blah
├── blah-26-blah
├── blah-27-blah
├── blah-28-blah
├── blah-29-blah
├── blah-30-blah
├── blah-31-blah
├── blah-32-blah
├── blah-33-blah
├── blah-34-blah
├── blah-35-blah
├── blah-36-blah
├── blah-37-blah
├── blah-38-blah
├── blah-39-blah
└── blah-40-blah
kos
  • 41,268
You can do:
#!/bin/bash
files=( blah-??-blah )
for ((i=${#files[@]}-1; i>=0; i--)); do
    first="${files[$i]%%-*}"
    num="$(grep -o '[0-9]\+' <<<"${files[$i]}")"
    last="${files##*-}"
        echo mv "$first-$num-$last" "$first-$((num+10))-$last"
done
If you are satisfied with everything, add | bash at the end to let the mv operation take place.
  • We have put the relevant file names into an array files
  • Then we have iterated over the elements of the array from the end i.e. from last to first
  • first will have the first part of file name i.e. part prior to the first -
  • last will have the last part of the file name i.e. the part after last -
  • num will have the number in between two -
  • mv "$first-$num-$last" "$first-$((num+10))-$last" will do the rename operation accordingly
Example:
$ ls -1
blah-10-blah
blah-11-blah
blah-12-blah
blah-13-blah
blah-14-blah
blah-15-blah
blah-16-blah
blah-17-blah
blah-18-blah
blah-19-blah
blah-20-blah
blah-21-blah
blah-22-blah
blah-23-blah
blah-24-blah
blah-25-blah
blah-26-blah
blah-27-blah
blah-28-blah
blah-29-blah
blah-30-blah
blah-foo-1
blah-foo-2
$ for ((i=${#files[@]}-1; i>=0; i--)); do first="${files[$i]%%-*}" \
    num="$(grep -o '[0-9]\+' <<<"${files[$i]}")" last="${files##*-}"; \
      echo mv "$first-$num-$last" "$first-$((num+10))-$last"; done
mv blah-30-blah blah-40-blah
mv blah-29-blah blah-39-blah
mv blah-28-blah blah-38-blah
mv blah-27-blah blah-37-blah
mv blah-26-blah blah-36-blah
mv blah-25-blah blah-35-blah
mv blah-24-blah blah-34-blah
mv blah-23-blah blah-33-blah
mv blah-22-blah blah-32-blah
mv blah-21-blah blah-31-blah
mv blah-20-blah blah-30-blah
mv blah-19-blah blah-29-blah
mv blah-18-blah blah-28-blah
mv blah-17-blah blah-27-blah
mv blah-16-blah blah-26-blah
mv blah-15-blah blah-25-blah
mv blah-14-blah blah-24-blah
mv blah-13-blah blah-23-blah
mv blah-12-blah blah-22-blah
mv blah-11-blah blah-21-blah
mv blah-10-blah blah-20-blah
    num="$(grep -o '[0-9]\+' <<<"${files[$i]}")" last="${files##*-}";\
      echo mv "$first-$num-$last" "$first-$((num+10))-$last"; done | bash
$ ls -1
blah-20-blah
blah-21-blah
blah-22-blah
blah-23-blah
blah-24-blah
blah-25-blah
blah-26-blah
blah-27-blah
blah-28-blah
blah-29-blah
blah-30-blah
blah-31-blah
blah-32-blah
blah-33-blah
blah-34-blah
blah-35-blah
blah-36-blah
blah-37-blah
blah-38-blah
blah-39-blah
blah-40-blah
blah-foo-1
blah-foo-2
heemayl
  • 93,925
Basic idea of this approach is to throw all the files into temporary "basket" directory, and then pick them out one by one, create new name , and move back with new name into the original directory.
The script bellow takes a single argument ( $1 ), which is directory where the files you want to rename are located.
Demo
xieerqi:$ ls testdir
blah-10-blah  blah-20-blah  blah-30-blah  blah-40-blah
xieerqi:$ cat testdir/*
I am file 10
I am file 20
I am file 30
I am file 40
xieerqi:$ ./incrementNames.sh testdir
blah-10-blah ../blah-20-blah
blah-20-blah ../blah-30-blah
blah-30-blah ../blah-40-blah
blah-40-blah ../blah-50-blah
blah-20-blah  blah-30-blah  blah-40-blah  blah-50-blah  TMP/
xieerqi:$ cat testdir/blah
xieerqi:$ cat testdir/blah-20-blah
I am file 10
xieerqi:$ cat testdir/blah-30-blah
I am file 20
Script
#!/bin/bash
if [ "$#" -ne 1 ]; then
    echo "Usage: incrementNames.sh /path/to/dir" && exit
fi
# navigate to target directory
# create temporary directory
cd "$1"
mkdir TMP
# move everything to TMP directory
find . -maxdepth 1 -type f -iname "*-*" -exec mv -t TMP {} \+
# drop down to TMP directory pick filesback into the directory , and rename them as we go
cd TMP
find .  -maxdepth 1 -type f -iname "*-*" -printf "%f\n"  | sort  | while IFS= read FILENAME
do
        NEW="$( awk -F '-'  '{print $1FS$2+10FS$3 }' <<< "$FILENAME")"
        echo "$FILENAME" "../$NEW"
        mv "$FILENAME" ../"$NEW"
done
Limitation
This script is specifically for files following pattern text-number-text, or at least text-number patter. It wont work for others
