I have this script that I am trying to execute on my machine Ubuntu 14.04, which indicates that I should Manage the ssh keys on servers to avoid entering password each time, which I didn't know how to, and the execution keeps asking me for a password (then I type the computer password) but it gives that the permission was denied,
As mentionned in the script, my machine will be both the server and client
Would you please help me about what to do, how should I configure the ssh connexion?
THANKS
In your case "Server" and "Client" are that same computer.
Client side settings
Generate SSH keys pair.
mkdir ~/.ssh
cd ~/.ssh && ssh-keygen -b 2048 -t rsa -C "My Comment for key" -t "access_key"
Detailed information about ssh-keygen options you can read in man page:
man ssh-keygen
After that you can find two files access_key and access_key.pub in ~/.ssh/
Create file with name "config" in your ~/.ssh directory. This file allow you to set up different settings for each host you need to connect.
Here is simple content of this file
Host my.remote-host.com
   User remoteusername
   Identityfile ~/.ssh/access_key
my.remote-host.com - target host to connect to (localhost)
remoteusername - login name of user on remote machine
Identityfile - path to you private key
Server side settings
How to enable "PublickKey" authentication:
sudo nano /etc/ssh/sshd_config
Uncomment next lines:
RSAAuthentication yes
PubkeyAuthentication yes
AuthorizedKeysFile     %h/.ssh/authorized_keys
RSAAuthentication - enable RSA keys support
PubkeyAuthentication - enable authentication by public keys
AuthorizedKeysFile - path to file that contain public keys
Restart your ssh server
sudo service sshd restart
Create directory and set correct permissions
mkdir ~/.ssh
sudo chmod 700 ~/.ssh
Create file for public keys and set correct permissions
touch ~/.ssh/authorized_keys
sudo chmod 600 ~/.ssh/authorized_keys
Put your public key (access_key.pub) into ~/.ssh/authorized_keys
You should use only one line per each key. Example:
ssh-dss AAAAB3NzaC1kc3MAAAbC2kVOJpcnfu7UqKV44uZ/khiP9K7F...aoSe MyComment
How to completely disable password authentication
Change PasswordAuthentication from "yes" to "no" Restart sshd server
