18
I have been using Ubuntu on VMware Player; today when I logged into VMware, it showed updates available for Ubuntu 15.xx. I allowed the updates and after downloading all the packages it restarted automatically, but never booted back. It is throwing messages like
Piix4_SMBus: 000:00:07.3: Host SMBus controller bus not enabled
failed to start /etc/rc.local compatibility
Please describe a way to fix it!
Murali G
  • 181
5 Answers5
12
First, add this line in your vmx file to increase the boot time to 50s
bios.bootDelay = "50000"
Start the VM, hold the left shift key down, then hit Enter.
In the grub menu, choose Advanced options for Ubuntu -> Recovery mode. Once the system boots, choose 'Root' to drop into a root shell.
In the root shell, enter the following commands
mount -o remount,rw /
nano /etc/modprobe.d/blacklist.conf
go down a few lines (almost anywhere) and enter the line
blacklist i2c-piix4
Then press ctrl+o to save the file, and ctrl+x
Finally, enter the command
reboot
zs2020
  • 183
Charles Green
  • 21,859
The method above didn't work for me on Ubuntu 16.10 and VMWare Workstation 12.5.1..
Boot into Ubuntu Recovery Mode --> drop into the root shell and open the kernel blacklist config file.
Then add this line into the file and save.
blacklist intel_powerclamp
I found this solution from this post:
https://websiteforstudents.com/question/student-question-resolve-ubuntu-16-10-piix4_smbus-host-smbus-controller-bus-not-enabled/
John
  • 41
At first, open *.vmx file from your VMware folder via notepad. Then add this line to the file and save it.
cpuid.1.eax = "0000:0000:0000:0001:0000:0110:1010:0101"
The problem will be fixed.
storm
  • 5,013
teardrop
  • 131
I was able to solve the problem by dropping into safe mode and running clean.
EDIT:
This was done holding shift when rebooting the VM. when in the grub go to "advanced options". Then in that menu run "clean"
Although I'm late to the party, the solution to your other problem (failed to start /etc/rc.local compatibility etc., as described in the later comments to Charles Green's answer) is most probably (at least was for me), to wipe old, incompatible vmhgfs (shared VM disk) settings/module, since they break a couple of things.
First, the module doesn't load if there are version mismatch etc. Remove vmhgfs from /etc/modules, and now the init should run properly.
Secondly, if you added a fstab entry for your vmhgfs, systemd-fstab-generator generates a systemd startup task for it, also resulting in failed systemctl unit. Comment out or remove your vmhgfs line in fstab, and remove the relevant mnt-*.mount (e.g. mnt-vmhgfs.mount) files from your /run/systemd/generator. That should fix the 2nd part of the problem.
