TLDR: upgrade to 15.10 from 15.04 appears to have altered my access to sda5 encrypted system. Ubuntu recognises the password as correct, but fails to access. Ultimately, I'd like to be able to access this system again.
I upgraded from 15.04 to 15.10 yesterday. When I enter my sda5_crypt password (but only my correct password - if I enter an incorrect password I'm told incorrect password and prompted to re-enter), I'm met with a message of
cryptsetup: unknown fstype, bad password or options?
followed by
cryptsetup: sda5_crypt set up successfully
At which point system checks begin. Here the problems outlined are:
/run/lvm/lvmetad.socket: connect failed: No such file or directory
WARNING: Failed to connect to lvmetad. Falling back to internal scanning.
Reading all physical volumes. This may take a while...
Found volume group "ubuntu-vg" using metadata type lvm2
2 logical volume(s) in group "ubuntu-vg" now active
device-mapper: remove ioctl on sda5_crypt failed: Device or resource busy
[previous line repeats 24 times]
Device sda5_crypt is still in use.
fsck from util-linux 2.62.2
/dev/mapper/ubuntu--vg-root: recovering journal
/dev/mapper/ubuntu--vg-root: clean, 369962/45268992 files, 129447388/181049344 blocks
[**FAILED**]Failed to activate swap /dev/mapper/ubuntu--vg-swap_1.
See 'systemctl status "dev-mapper-ubuntu\\x2d\\x2dvg\\x2dswap_1.swap"' for details
[**DEPEND**] Dependency failed for Swap.
[ OK ] Found device WDC_WD7500BPKX-22HPJT0 1.
[ OK ] Started GNOME Display Manager.... and deal with any system changes.signatures....ut down.....
At which point startup ceases.
Advanced options for boot give me two kernel options; 3.16.0-34-generic fails to find kernel, while the version 4 kernel freezes before entering the GUI. Can access GRUB, however.
Mounting the hard drive to another computer running 15.04 shows the full disk, but the password for sda5_crypt is unable to access the information, though I can access the GRUB section of the disk.
