My touchpad is detected as a mouse so no scrolling is possible.
  • laptop Asus G550JK, Xubuntu 14.04.2
  • dkms installed
  • xinput gives me "PS/2 Generic Mouse" where Elantech Touchpad should be
  • my touchpad seems to be ETD0105
  • already tried this
    sudo apt-get --purge autoremove xserver-xorg-input-synaptics && sudo apt-get install xserver-xorg-input-synaptics
  • and this
    sudo apt-get install --install-recommends xserver-xorg
  • and this
    sudo modprobe -r psmouse && sudo modprobe psmouse proto=imps
  • and tried to reconfigure driver according to this
    https://hardc0l2e.wordpress.com/2014/12/06/fix-for-elantech-touchpad-on-ubuntu-14-04/
  • dkms status gives me
    focaltech, 1.5~trusty1: added psmouse, elantech-x551c, 3.19.0-30-generic, x86_64: installed vboxhost, 4.3.30, 3.19.0-30-generic, x86_64: installed
Any help would be truly appreciated :-) Thank you.
Sebastian
  • 1,238
I finally found the right solution that @jandurek pointed out here.
sudo rmmod psmouse
sudo insmod /lib/modules/`uname -r`/kernel/drivers/input/mouse/psmouse.ko
I added this to a startup script to enable two-finger scrolling right after ubuntu starts.
Sebastian
  • 1,238
The problem is very clear. You installed a wrong Focaltech touchpad driver.
And it is installed from my PPA. Remove it this way:
sudo apt-get purge focaltech-dkms
sudo add-apt-repository ppa:hanipouspilot/focaltech-dkms
Then reboot.
The touchpad should work without any driver.
So also remove the Elantech one too by:
sudo dkms remove psmouse/elantech-x551c --all
If the touchpad does not work, then re-install the Elantech driver. I am not 100% sure that this specific model works on kernel 3.19.
Pilot6
  • 92,041
