Personally , when it comes to setting custom nameserver I prefer using supersede option in /etc/dhcp/dhclient.conf file. When you connect to access point , the router sends some infomation to your machine, including what DNS it should be using. supersede takes that option and replaces that setting with whatever you provide. More precisely, I'd use supercede domain-name-servers 8.8.8.8;
Here's the example of my file's top part. Notice where I set that option
xieerqi:$ cat /etc/dhcp/dhclient.conf | head -n 30
# Configuration file for /sbin/dhclient, which is included in Debian's
# dhcp3-client package.
# This is a sample configuration file for dhclient. See dhclient.conf's
# man page for more information about the syntax of this file
# and a more comprehensive list of the parameters understood by
# dhclient.
# Normally, if the DHCP server provides reasonable information and does
# not leave anything out (like the domain name, for example), then
# few changes must be made to this file, if any.
option rfc3442-classless-static-routes code 121 = array of unsigned integer 8;
#send host-name "andare.fugue.com";
send host-name = gethostname();
#send dhcp-client-identifier 1:0:a0:24:ab:fb:9c;
#send dhcp-lease-time 3600;
#supersede domain-name "fugue.com home.vix.com";
supersede domain-name-servers 208.67.220.220; ###### <--------
#prepend domain-name-servers 127.0.0.1;
request subnet-mask, broadcast-address, time-offset, routers,
domain-name, domain-name-servers, domain-search, host-name,
dhcp6.name-servers, dhcp6.domain-search,
netbios-name-servers, netbios-scope, interface-mtu,
rfc3442-classless-static-routes, ntp-servers,
dhcp6.fqdn, dhcp6.sntp-servers;
#require subnet-mask, domain-name-servers;
#timeout 60;
