After upgrading from 11.04 (N.N.) to 11.10 (O.O.), I have many problems. The first problem is that I was expecting Gnome to be updated to Gnome 3. However, sysinfo reports:
Release: Ubuntu 11.10 (oneiric)
Gnome:   2.32.1
Kernel:  3.0.0-12-generic
I executed the unity_support_test to assure that Unity 3D is supported by my graphics hardware. The result follows.
1$ /usr/lib/nux/unity_support_test -p
OpenGL vendor string:   ATI Technologies Inc.
OpenGL renderer string: AMD Radeon HD 6620G
OpenGL version string:  4.1.11005 Compatibility Profile Context
Not software rendered:    yes
Not blacklisted:          yes
GLX fbconfig:             yes
GLX texture from pixmap:  yes
GL npot or rect textures: yes
GL vertex program:        yes
GL fragment program:      yes
GL vertex buffer object:  yes
GL framebuffer object:    yes
GL version is 1.4+:       yes
Unity 3D supported:       yes
However, I cannot discern whether Unity 3D is actually executing. It looks identical to Ubuntu 2D (as identified on the session login screen), which I am guessing is the Unity 2D configuration.
My question is: Why is sysinfo reporting Gnome 2 rather than Gnome 3?
a very very easy solution (even for Ubuntu-dulls or my mother in law...who is using also ubuntu) if Ubuntu is not upgrading properly, just download 11.10, burn it on a CD and install it!!! It will detect a previous failed installation and will correct it. All installed programs and most settings are keep as original. I was surprised how well it worked when I run into a problem while upgrading. My upgrade got stuck after rebooting at 'checking battery state' due to interruption of my wireless Internet while upgrading. Hope this helps for others as well!!!
