This problem occured while installing virtualbox-5.0_5.0.8-103449~Ubuntu~trusty_i386.deb, what should I do?
- 41,268
When upgrading Virtual Box to a newer major release version (e.g. from 4.x to 5.x) we need to remove the older version first to be able to proceed.
Removal of a package depends on how you had installed it. In most cases you can use the Software Center to remove installed packages. In case you had installed Virtual Box from the repositories it is the package virtualbox you will have to remove.
If a package is not listed there, or if we had installed it from another source we may also issue the following command in a terminal (for removal of virtualbox 4.0):
sudo apt-get remove virtualbox-4.0
Note that your settings and your existing virtual machines will stay untouched, they will not be removed.
After that we can safely re-install Virtual Box from a DEB file we had downloaded, or by adding the Oracle repository to our sources, which will always install the most recent version (at present 5.0.8). After upgrading Virtual Box we should also upgrade the Guest Additions in our virtual machines.
