I'm currently trying to setup a mattermost-1.1.1 instance on an Ubuntu LTS 14, which was pretty straightforward.
I configured the service to listen to 127.0.0.1:8065 only and want to do a ReverseProxy via Apache2 on the same host using this configuration
<VirtualHost *:443>
SSLEngine on
SSLProtocol all -SSLv2
SSLHonorCipherOrder on
SSLCipherSuite "ECDHE-RSA-AES128-SHA256:AES128-GCM-SHA256:RC4:HIGH:!MD5:!aNULL:!EDH"
Header add Strict-Transport-Security: "max-age=15768000;includeSubdomains"
SSLCompression Off
SSLCertificateChainFile /etc/apache2/ssl/zcore_ORG_chain.pem
SSLCertificateFile /etc/apache2/ssl/zcore.intra.pem
SSLCertificateKeyFile /etc/apache2/ssl/zcore.intra.key.pem
ServerName mattermost.zcore.intra
ServerSignature Off
ServerAlias mattermost
ProxyPreserveHost On
AllowEncodedSlashes NoDecode
<Location />
Require all granted
ProxyPass http://mattermost.zcore.intra:8065
ProxyPassReverse http://mattermost.zcore.intra:8065
</Location>
LogFormat "%{X-Forwarded-For}i %l %u %t \"%r\" %>s %b" common_forwarded
ErrorLog /var/log/apache2/mattermost.zcore.intra/mattermost.zcore.intra_error.log
CustomLog /var/log/apache2/mattermost.zcore.intra/mattermost.zcore.intra_forwarded.log common_forwarded
CustomLog /var/log/apache2/mattermost.zcore.intra/mattermost.zcore.intra_access.log combined env=!dontlog
CustomLog /var/log/apache2/mattermost.zcore.intra/mattermost.zcore.intra.log combined
</VirtualHost>
<VirtualHost *:80>
Redirect permanent / https://mattermost.zcore.intra
</VirtualHost>
The redirect works fine so far, but after a few seconds logged in I get the following message displayed on the site:
We cannot reach the Mattermost service. The service may be down or misconfigured. Please contact an administrator to make sure the WebSocket port is configured properly.
[2015/10/28 10:52:00 CET] [EROR] websocket connect err: websocket: could not find connection header with token 'upgrade'
[2015/10/28 10:52:00 CET] [EROR] /api/v1/websocket:connect code=500 rid=emfn13fxjtnhpgp6nfrmoqdupw uid=f18pts15ib8xz8s4igctmm4ofa ip=192.168.3.128 Failed to upgrade websocket connection [details: ]
I guess there's something missing in my configuration.
