How do I remove the shutdown confirmation menu saying "are you sure you want to shut down"? This is the menu that pops up after I press shut down.
I can't navigate to it in gconf_editor using the old instructions for 10.04 or 11.04.
Rockishi
  • 623
For 11.10
Run dconf-editor
(either Alt+F2 or from terminal, must be installed first)
/org/gnome/gnome-session/
uncheck "logout-prompt"
I still haven't found a way to return restart to the menu and suppress that confirmation.
(thanks for the edit fossfreedom)
For 10.04/10.10 & 11.04
Run gconf-editor
(either Alt+F2 or from terminal)
/apps/gnome-session/options
uncheck "logout_prompt"
/apps/indicator-session
check "suppress_logout_restart_shutdown"
This will remove the annoying dialog in releases preceding Oneiric Ocelot.
Ubuntu 13.10
Open a terminal and run gsettings set com.canonical.indicator.session suppress-logout-restart-shutdown true. This will disable the dialog.
by Donarsson: shut down without extra question
rubo77
  • 34,024
  • 52
  • 172
  • 299
For me in Ubuntu 11.10:
sudo apt-get install gconf-editor dconf-tools
dconf-editor
Go to /apps/indicator-session
Enable: suppress-logout-restart-shutdown
Cheers!
fossfreedom
  • 174,526
Costales
  • 2,318
