the Dropbox indicator doesn't work anymore in Ubuntu 15.10. Tried installing appindicator1 and restarting dropbox, but still no indicator appears. How to get it working?
Aslanex
  • 192
This one
Worked in Ubuntu 16.04 lts Flashback Compiz
  1. Kill dropbox, and restart it so it shows
    dropbox stop && env XDG_CURRENT_DESKTOP=Unity dropbox start
    If it works
  2. Go to the settings in dropbox after it starts up and select to not start at startup.
  3. Go to Applications > Preferences > Startup Applications and click on add and
Enter
Command: env XDG_CURRENT_DESKTOP=Unity dropbox start
Comment: Sync your files across computers and to the web
and save
Vijay
  • 8,556
Something which worked for me was
  1. apt-get install nautilus-dropbox
  2. check that it worked with Unity but not with the environment I'm using (gnome-fallback, it used to work with it before at least with 14.04),
  3. check that it worked under gnome-fallback with
    dropbox stop && XDG_CURRENT_DESKTOP=Unity dropbox start
    (gnome-fallback used to have XDG_CURRENT_DESKTOP=Unity, in 15.10 it has a prefix before Unity).
  4. Create a file ~/scripts/startDropbox (and ensure it is executable with chmod 755 ~/scripts/startDropbox)
    #! /bin/sh
    set +e
    if expr "$XDG_CURRENT_DESKTOP" : '.*Unity' > /dev/null ; then
        export XDG_CURRENT_DESKTOP=Unity
    fi
    # yes, ! is counter intuitive here
    if ! dropbox running ; then
        dropbox stop
    fi
    dropbox start -i
  5. Create a ~/.config/autostart/my-dropbox.desktop (dropbox will overwrite your changes if you try to modify ~/.config/autostart/dropbox.desktop)
    [Desktop Entry]
    Name=Dropbox
    GenericName=File Synchronizer
    Comment=Sync your files across computers and to the web
    Exec=/home/AProgrammer/scripts/startDropbox
    Terminal=false
    Type=Application
    Icon=dropbox
    Categories=Network;FileTransfer;
    StartupNotify=false
Try:
sudo apt-get install libappindicator1
Log out, and then log back in and use:
dropbox stop && dropbox start
For what's it worth I solved this problem by running 'dropbox stop' then 'dropbox start'in my list of startup programs in Ubuntu 15.10. I took care, even though it might be unnecessary, to use the STOP option first. The indicator then shows correctly and syncing works.
