it says this on the bottom right of my computer, its says ''this usually means that you installed packages that have unmet dependecies.''
I did Run df -i in terminal and it gave me this :
udev            214773    487  214286    1% /dev
tmpfs           219974    657  219317    1% /run
/dev/sda1      9740288 443560 9296728    5% /
tmpfs           219974      1  219973    1% /dev/shm
tmpfs           219974      5  219969    1% /run/lock
tmpfs           219974     15  219959    1% /sys/fs/cgroup
tmpfs           219974     21  219953    1% /run/user/1000
If I try apt-get update I get this :
E: Unable to lock the administration directory (/var/lib/dpkg/), are you root?
Last thing I tried was : sudo apt-get purge libreoffice-core
It said :
 dh-python : Depends: libdpkg-perl but it is not installed
